Fast trac tops
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 69K5, Nov 29, 2001.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    If i install a fast trac tops will a factory roll bar get in the way?? and also willl i be able to take it off easily and put my hard top back on???
  2. tmanofcali
    tmanofcali 1/2 ton status
    Mar 20, 2001
    372
    lodi, ca
    you should have no problems with a stock roll barwith the fastrac system. also the top wouldnt be too hard to take off to install your hard top. if you need some pics of the fastrac installed look at my webshots page.
    <a target="_blank" href=http://community.webshots.com/user/tmanofcali1>http://community.webshots.com/user/tmanofcali1</a>
  3. Rhody
    Rhody Registered Member
    Oct 8, 2001
    22
    Wallingford, WA
    I have another question on these Fast Trac tops. I put mine on about a month ago. It went on pretty tight. My problem is that the thing is streched out to the point where the zippers are a pain in the a$$ to zip and they leak in the rain. Does anyone have a cure for this leaking problem around the zippers?
    Little Rhody
  4. clarkekent
    clarkekent Registered Member
    Sep 26, 2000
    69
    NY
    Try some tent sealer around the seams... you can get it at any camping or sporting goods store.
  5. Rhody
    Oct 8, 2001
    22
    Wallingford, WA
    AHHHHHH!! Good Call.. I did not even think about that?
    Little Rhody
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    tmanofcali,
    thanks for the help and the pic's. blazer looks good. are you happy with the lipping system on the top? thanks again
    nathan
  7. tmanofcali
    Mar 20, 2001
    372
    lodi, ca
    nathan, so far i like the lip on the top. just dont roll down your window before you drive around the block first. it tends to shoot right threw the window...lol. we have had some really hard rain and winds lately and everything seems to be holding up good. later......todd
