Favorite Products
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CrazeeBush, Jun 8, 2000.
  1. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    Okay, just want to hear what everyone's all time fav products are. I'll start off with fav.
    -Simple Green- Man, this stuff will clean just about anything! In the restoration of my truck, I must have used 2 gallons of this stuff.
    -Rubberized Undercoating-Gotta love this stuff, useful for sound deadning,rust prevention, and so on. Everywhere that is covered by carpet of panels in my truck, if you look behind you'll see this on my truck.
    -WD40- Every one knows how useful this stuff is, you can clean funk off of anything, grease something up, Anytime somethng doesn't work right spary on some WD and it'll be okay.
    -VHT Vinyl Dyes- I've dyed every panel in my truck in cluding my dash with this. I took it from ugly tan to black. It goes on easy and doesn't wear off.
    -JoSH
    crazeebush@aol.com
    http://josh.coloradok5.com
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    PB Blaster - breaks loose those stubborn corroded bolts and nuts!
    Krylon - scrape a tree, spray on some more!
    Brake Kleen - makes for removing grease easily and works good as a hand cleaner!
    Mobil 15w-40 motor oil - helps stop oil leaks on old worn out engines.. :)
    Mike
    1982 GMC Jimmy - Emmett
    http://emmett.coloradok5.com
  3. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    i gotta go with bic on this one...........
    <font color=purple>delta9blazer</font color=purple>
  4. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Formula 12/34 - will dry out anything(ie spark plug wires, distributors, etc)
    RainX- Man, I swear by this stuff. We were on the East Coast during a tropical storm and the wiper motor failed, the RainX just makes it bead right off!
    PS- check out the spinnin' Texas!
    http://www.blazer.coloradok5.com is now under construction[​IMG]
    YEEEE HAWWWW[​IMG]
  5. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    What brand undercoating did you use? How many cans did you use for underneath the truck? I wanna do this to my truck before it becomes a rust bucket. Do you have to wear any special clothing so you don't get the crap all over your skin? I need some info before I get the stuff all over me if I attempt it.
    J.D.
    88 Gmc Jimmy
  6. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
    I forgot about the Rain-X, that stuff is awesome! I love it. Undercoating: I use whatever they sell at AutoZone, I don't have any to look at right now. You don't want to get that on your skin, it's a pain in the butt, I promise you. I use rthe rubberized kind if that helps..
    -JoSH
    crazeebush@aol.com
  7. MudRebel350
    May 20, 2000
    324
    N.J.
    How thick of a coat of this stuff do you put on? I'd like to stop the rust before it creates holes.
    J.D.
    88 Gmc Jimmy
  8. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    B-12 Carb cleaner. Cleans parts, brakes, carbs, not good for buffing paint though. [​IMG] without berrymans, I'd be lost.
    [​IMG][​IMG]
    Durant, Ok
    '79 Blazer in progress
  9. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Many of my favorites have been mentioned, but for cleaning things....you cannot get it any better then Super Clean by castrol. I buy it by the 2.5 gallon size for the house, rig and work. It will take the wax off your truck and clean your tires leaving them look like they have been armor alled. Turn your wipers on and spray the windshield and the glare is gone along with the squeaks...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You might want to read the cautionary statements on the can before spraying that stuff on your hands. I don't think they intended it as a hand cleaner. It probably isn't very good for you to put it directly on your skin.
    Spend a buck, get a can of GoJo. [​IMG]
    http://ThunderTruck.ColoradoK5.com
  11. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Harry reminded me of Gojo, this stuff just makes the grease slide right off you arms. Fast Orange is also good, but I don't like the smell.
    YEEEE HAWWWW[​IMG]
  12. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
    For grease, good ol' dish soap works well. It's made to clean grease off of dishes, and it works just as well on K5 grease. =) If I'm really funky I might use carb cleaner hehe.
    -JoSH
    crazeebush@aol.com
  13. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Automatic transmission fluid also does an excellent job of removing really nasty grease and dirt mixtures. Gets your hands clean quickly. Then use a GoJo (or Dawn) [​IMG] to get the ATF off of your hands.
  14. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    OK all the good ones have been mentioned, so I will move the favorite product field to....BEER!!
    Call me crazy but ain't notin like a cold beer with your hands coverd in K5 grease/gear oil/brake fluid/road grime
    who cares I'm thirsty crack open a cold one I can fix anything or at least break it trying [​IMG][​IMG][​IMG][​IMG][​IMG]
    Have a GREAT weekend guys......
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  15. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    Detroit Lockers, Super Swampers, Warn winches are my three favorite products.
    CB
  16. Burt4x4
    6,854
    AZK5
    There ya go lets change it to Favorite bolt ons!
    My third foot for thoes cluch/brake/gas situations is a great bolt on for the stick driver!!
    Third foot = Mico Lever-Lock
    KMA bumper is a cool bolt on too
  17. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Tow straps and tow hooks.
    Rhino Liner - great stuff, just very expensive. You'd have to use a torch or a jackhammer to get it off.
    YEEEE HAWWWW[​IMG]
  18. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    Swampers,Rancho lifts.Detriots,Sawzall,Tow straps,Screw drivers,(to fix carb)Duck tape!,High lift,My third foot is a hood cable pull from a 84 chevy truck modified to work as a throttle just pull it with the right hand!I have it mounted on the dash to the left of the ashtray.Brady
