Fawked up D60 knuckle....help
Discussion in 'The Garage' started by Bushwhacker, Nov 1, 2003.
  1. Bushwhacker
    Bushwhacker 1/2 ton status GMOTM Winner
    May 13, 2002
    796
    Indian Trail,North Carolina
    Well My knuckle is fawked for the moment. I was installing my steering arm and saw that the studs needed to go farther into the knuckle, well I went and started removing them to tap the holes out and clean up the threads. The first stud came out and ate all the threads in the knuckle. the others were fine. What the hell can I do to fix it without spending $$$$$$$$ for some Dedenbear knuck's???? Heli coil?
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
    Clay
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Heli coil will work or drill them out and retap them one size bigger in bolt size /forums/images/graemlins/thumb.gif
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I stripped one of the bolt holes out of mine D60 knuckle and called Steve Watson ans he suggested a HeliCoil so I went that route...
    Chris
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Before trying anything else, why don't you run a tap in the hole and see how bad the threads really are?
  5. Bushwhacker
    May 13, 2002
    796
    Thanks for the input guys. I did try a tap but there was only about 1/4 inch of thread left. I got it fixed this afternoon. I went with the helicoil and it worked great!! /forums/images/graemlins/thumb.gif
    Thanks,
    Clay
