Fawkin wiper ghost
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Jun 19, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    My wipers are now at the stage where they just keep going.If I replace the wiper/blinker arm will they stop going on there own? /forums/images/icons/tongue.gif
  2. JROSS
    JROSS 1/2 ton status
    Oct 12, 2001
    281
    Redding, CA
    I had a similar problem with my 68 Camaro. Ended up being the contacts in the motor housing were not disconnecting. I openned up the housing and bent the contacts out. I'm not sure how similar the wiper motors are between then and your year. Not sure if this helps but /forums/images/icons/tongue.gif
  3. UseYourBlinker
    Jun 7, 2000
    11,117
    How can I dissengage the wipers,so they will not work?
  4. Ben Malinski
    Ben Malinski Guest
    Pull the fuse.
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    on my truck that was the plastic cam/gear that allowed a few wipes when the washer fluid was used
