Feelin' Fishy?
Discussion in 'The Garage' started by gruveb, Jun 29, 2003.
  1. gruveb
    gruveb Registered Member
    Jun 26, 2003
    51
    Rio Rico, Arizona
    Feelin\' Fishy?
    Upon occassion the back end of my Blazer wanders, bounced and around and causes the vehicle to wabble side to side. This is a little scary when you're going 45 mph!
    What could cause this?
    I have a 4" suspension lift, 2" body lift (thinking of removing the body lift and getting adding 2" of springs, 35" tires, rancho 9000 series shocks.
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Re: Feelin\' Fishy?
    Make sure U-Bolts are tight....
  3. gruveb
    Jun 26, 2003
    51
    Rio Rico, Arizona
    Re: Feelin\' Fishy?
    Never thought of that. They look tight, but I'll check. ANything else?
  4. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Re: Feelin\' Fishy?
    Mmmmm, lug nuts, loose bolts on the springs/hangers, missing or badly worn bushings, something broke????
    Just inspect the whole shebang, shake, pull, tug on everything in sight, and put a wrench to it all to make sure all is well.....
  5. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    Re: Feelin\' Fishy?
    does it happen out of the blue or when you hit a row of bumps? theres a spot going to work that does it to mine, i watch other people in front of me sometimes and they stay strait. the short wheel base will do it on some bumps. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  6. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Re: Feelin\' Fishy?
    Are the shocks any good????
  7. gruveb
    Jun 26, 2003
    51
    Rio Rico, Arizona
    Re: Feelin\' Fishy?
    Well, they are 9000 series Ranchos, maybe 20 years old or so, so they should be fine. I guess I'll take one off and see how it responds.
    It seems to happen out of the blue too.
  8. boggerless
    May 26, 2003
    22,728
    96
    Re: Feelin\' Fishy?
    yea, that's actually my new truck that does that.a friend of mine has a 00 dodge off-road and he hates that truck, the short wheel base makes it ride rough.i told him if you want cushy buy a car. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  9. gruveb
    Jun 26, 2003
    51
    Rio Rico, Arizona
    Re: Feelin\' Fishy?
    This is more than uncomfortable, it's down right scary; nearly causes a loss of control. That's a really BAD thing in my opinion.
    I dont' mind a rough ride, heck, it's a big ole offroad vehicle, it's wonderful in the dirt.
  10. boggerless
    May 26, 2003
    22,728
    96
    Re: Feelin\' Fishy?
    i was making fun of my friend about the ride. check you tires they may be falling apart or blems or the wheel weights fell off,(don't laugh my 36's are balanced, no poop) the tires i'm talking about really are. the drivers front has 8 lbs. on it ,crazy huh.the passenger side HAD 15lbs.but the caliper took care of that. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  11. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Re: Feelin\' Fishy?
    Bad shocks plus really worn springs might cause this???????
  12. gruveb
    Jun 26, 2003
    51
    Rio Rico, Arizona
    Re: Feelin\' Fishy?
    The springs are so new that they actually have the sticker on them still!
    These shocks are adjustable, so maybe I'll go set them as stiff as I possibly can and see.....
