Fel Pro 1 piece oil pan gasket
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 8_YOUR_H2, Apr 24, 2000.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    I have had the small block leak that is so common, around the front (timing chain) and the rear of the pan..well I bought the bad ass fel pro gasket and it is sweet!! I told the guy at O'rieley's I Wanted the best, it is a 1 piece gasket with all of the bolts and these plastic doo-hickey's that hold the gasket up so you can align the pan!! If anyone else is suffering from this same problem this is a sure fire way to fix it!!
