felt for a jeep today
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RESTORE89, Aug 14, 2001.
  1. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    going down the road today and ion the mediun was an older jep maybe a cj-5 with about 4 inches of lift and 35's, kind of plain you know, a real usable rig, not a juiced up street rig, and the guy had a cop behind him with the lights going and i look down and his whole drivers side axle and wheel are laying up next to the rig with the rear end laying in the asphalt with a big gouge in road leading to wher he stopped. I thought man thank sucks big time. it is bad enough when we break things having fun off road, but the guy was just driving down the road. What would have to happen to have your axle come complety out like that? [​IMG]
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>He broke the axle. The shafts on semifloating axles (like what comes in K5s) will seperate from the vehicle if it is to break since its held in by a clip in the differential. </font color=blue>
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    An axle can come completly out like that w/ a c-clip axle. ( YES! c-clip axles are whats in a Blazer from the factory ) What happens is the clip pops off, for whatever reason, or the shaft breaks and the shaft, brake drum, and wheel will part company w/ the rig.
    The only way to prevent this is to run c-clip eliminators, or a Full Float axle. And even w/ the eliminators, it IS possible to lose a wheel if it breaks off outside of the bearing. ( only seen that happen once. )
    I get all the excercise I need pushing my luck![​IMG]
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Must've been an AMC Model 20 rear end - No C-Clips or anything, just a tapered bearing holding it all in. And once that bearing goes - that's all she wrote.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    got to love those amc model 20 axles!
  6. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    YEAH The model 20 is as intelligent of an idea, as a football bat! [​IMG]
  7. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    I actually had that happen to me on my old truck. I had a 454 in it with the stock 1/2 ton axles still in it. I heard a loud pop and I started moving but, luckily I was in a parking lot and my friends saw my wheel to start moving out from the body. I had them kick the wheel in until I got to a safe place to park it.
    I broke it clean off about 2 inches from the end of the shaft where it went into the differential. I later upgraded to a 14 bolt that following summer!
    74 Blazer
    Zepplin
    Check out my Blazer <a target="_blank" href=http://community.webshots.com/user/zepplin1976>http://community.webshots.com/user/zepplin1976</a>
  8. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    That's what happened to me on my first wheeling experience.
    10 minutes into the run and my rear drivers tire and axle are sticking out to the moon. Those 10 bolt clips
    One way of learning......
    <a target="_blank" href=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </a>
  9. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    Oh man... ouch. Sounds like this guy has my kind of luck for differentials LOL. I have the third one going south cause of a bearing falure and I haven't even wheeled this thing yet! [​IMG]
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://www.geocities.com/milnerlives_2000/blazer.htm>http://www.geocities.com/milnerlives_2000/blazer.htm</a>
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    C-Clip eliminators suck for the street. They were designed for drag racing and they leak, all of them.
    I have had three different c-clip axles in my truck and I have never had any problem. I had a 10 bolt, then a 12, now a 14 SF. The 14 SF has monsterous shafts, 33 spines, and C-clips. It's not as good as a full floater, but it holds up quite well.
    Got to feel sorry for the Jeeper though. I guess it just goes back to what I've said for a long time. I don't really know what people see in Jeeps, as the driveline that comes in them is useless for any fourwheeling at any more than a stock level. You've got to swap out the whole thing to make a decent vehicle out of one.
    Tim
  11. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Early Jeeps had a killer drivetrain - Dana 44FF rear, Spicer 30 front, T90 3 speed, Spicer 18 twin stick, and 5.34 gears - making an extremely capable rig in spite of a 70 HP engine.
    Dos mas Tecates!!!
  12. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    how hard is it to install a full floater kit from ORD? sounds like it would be a worthy investment.
  13. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    They are pretty easy - figure on a full afternoon to do it, plus time added for other jobs you decide to do while you're at it. I'm planning on doing mine once I get gainfully employed again, and add disc brakes, a better diff, and all new bearings and seals while I'm at it.
    Dos mas Tecates!!!
  14. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    What about the CJ7s that came stock w/V8s and automatics? Or a CJ5/7 w/a factory V8 and a T-18? Are those drivetrains useless for any fourwheeling? That AMC 20 has a bigger ring gear than the 10 bolt that came in your truck, too. The stock Heep axles are no worse than stock Chevy axles. Plus, they don't have c-clips.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  15. pcorssmit
    Jan 2, 2001
    1,346
    Denver, CO
    Posted by 84_Chevy_K10 above:
    "I have had three different c-clip axles in my truck and I have never had any problem. I had a 10 bolt, then a 12, now a 14 SF."
    Posted by 84_Chevy_K10 on a different thread, 8-16-01:
    "I destroyed a 12 bolt with a stock 305. If you're putting in a big block, I don't care what you do to a 12 bolt, you've still got an 8.875" ring gear and if you lock it and beat on it, you'll break it."
    I guess I always though that destroying a rear end would count as a problem, guess I was wrong again.
    Pete
  16. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    "Anything you post can and will be used aginst you by somebody..."
    Nice shot Pete!
    Rene
  17. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    [​IMG] play nice now boys [​IMG]
    what's in it now?
  18. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    [​IMG] I was playing nice...can't you see the nice little halo hovering above my head? [​IMG]
    Sorry Tim, just havin some fun.
    Rene
  19. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    i did not see any halo's hanging around, maybe some bent up 7014 sprayed gold and made to look round LOL
    i now where to go for any weld questions [​IMG]
    what's in it now?
  20. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    *crowd applauding*
    That was too good!!!! [​IMG]
    It's been lovely, but I have to scream now.
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer/>http://www.geocities.com/muddin4fun79blazer/</a>
