fender cutting...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddysub, Oct 25, 2001.
  1. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    is cutting into your truck's fenders scary? my sub is my daily driver so appearance matters. but should i try to cut my own fenders since i have no experience at it? i don't suppose 4x4 shops would do it for me, would they? or is there anyone in here that lives in las vegas, NV that has done their truck and would cut mine or atleast help me with my fenders. oh, last question, should i use a saws-all or die grinder?
    donate to the "Build Scott's Suburban Foundation"
    scott,
    1989 GMC suburban 3/4t 4" lift soon to be rollin on 36" swampers, tbi350, th350, np241
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    If you want to drive out here to So Cal, I'll help you out[​IMG]. It is actually pretty easy. I wouldn't use the sawzall for this as you may get a ripple effect going. I used an angle grinder with a thin cutoff wheel and it came out pretty good. You can't even tell I did it unless you look closely. Check out my webshots page down below and look at the fender cutting album.
    Esteban
    <a target="_blank" href=http://coloradok5.com/gallery/Estebans-album>Members Ride Pics.</a>
    <a target="_blank" href=http://community.webshots.com/user/geltyone>Webshots Pics.</a>
  3. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    i used a swazall with no ripple effect , didnt look that bad , did Esteban?
    WHATS WRONG WITH A 305 ?
    81 K10 GOODYEAR 35" MTRS
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  4. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    i used a swazall with no ripple effect , didnt look that bad , did it Esteban?
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  5. zcubed
    zcubed Registered Member
    Oct 15, 2001
    87
    Texas
    I used a sawzall, and it worked great!!! I was surprised. This was the first time i had ever done "real" work on my rig by myself. I wasn't worried about looks, but it still came out good. I thought it would be a HUGE headache, but it was painless. But like I say, I wasn't concerned about looks (but it doesn't look bad). Bottom line: If I can do it, ANYBODY can do it! :) BTW, after I was done, the tires cleared the cuts beautifully, BUT the tires rubbed on the back of the inner fenderwell (on extreme turns). I just hammered 'em out a little, and it worked fine. 33/12.50/15 -- no lift
    <font color=red>_____________________________________________________</font color=red>
    <font color=blue>I'm hooked on gin and tonics like yo mamma's hooked on phonics!</font color=blue>
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I plan to do mine soon. I don't have much choise since my tires rub both sides on the front fenders. I plan to use an airsaw to do them. Also I am going to bend a lip on the edges so it is a smooth surface instead of a sharp edge.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  7. Esteban86K5
    3,712
    Bakersfield, CA
    Andy your fenders look like crap!
    J/K[​IMG] I actually don't remember.
    Esteban
  8. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    thanks i like em that way
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  9. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    good , i folded mine makes it look trick , this is since Esteban saw em
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  10. k5texan
    k5texan 1/2 ton status
    Aug 1, 2001
    119
    Flint, TX
    how do you go about folding the fenders back
    thanks
    jared
  11. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I tried a pneumatic sawzall-like cutter and it didn't have the umpf to get through both the outer and inner fenders. I ended up using a die grinder to do the job. Cut through it like a hot knife through butter. But, it takes a lot more control to get a nice, clean cut from a die grinder than a sawzall. A tip, tape the area you plan to cut before cutting. It helps keep the cut clean.
    If you are terribly concerned with appearance, do like I did, install some fender flares. That way the cuts are completely covered by the flares. Doesn't matter how bad your cutting jub is, you will never see the edge of the sheet metal!
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  12. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Every time I break out the sawzall, my truck gets a chill...!!
    But really, the best tricks I've learned are to "duct tape" over the cutting area to minimize that "wavy, shaky" effect, and to cut down on scratches to the sheet metal that's still there. Also make sure to wear hearing and (need I say) eye protection.
    I've got a spare front clip off a '77 that really needs work - if you wanna practice on it!
    Marv
  13. zcubed
    Oct 15, 2001
    87
    Texas
    DITTO on that hearing. Man, it was loud!!!
  14. CK5
    May 19, 1999
    21,625
    702
    CO
    It is easy but any 4x4 shop will do them for you if you want.
    Steve
    Bandwidth FREE ZONE
    Mall-Running poseur 4x4 with curb-feelers
  15. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    I used a sawzall, but on trustyk5's advise found a 4" grinder with a cutting wheel worked better. The cutting wheels cut through the sheet metal like a hot knife through butter. I also felt the wheel was much easier to controll. Just my 2 lincolns,
    <font color=red> Elkboy </font color=red> 82 K5 fuel injected H.O.305, TH350/205, 14bolt/10bolt and 39.5 TSL's.
  16. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    cutting stuff up rocks. I use a sawzall, cutoff wheel, jig saw, circular saw with abrasive blade, tin snips, whatever I can get away with!
    Sherman, Tx
    <font color=red>The blazer's almost on the road....anyone got tree fiddy?</font color=red>
  17. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    cut about to where u want but leave about a 1/4 extra and then take a crescent wrench and a lil bit at a time start folding it under .
    TH350 NP 208
    O R D's axles
    NO BREAKAGE :)
  18. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Plasma cutter works too...but the grinder with a thin cut-off disc is my fave sheet metal hacking tool.[​IMG]
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  19. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    When I cut mine I just left about a 1/2" more than where I wanted the edge. Then I took small sledge hammer and pounded the a lip back over so it lays flat against the inner fender.
    Jim '80 GMC & '73 Blazer
    Body by Tellico
    <a target="_blank" href=http://www.tellicok5.rockcrawler.com>www.tellicok5.rockcrawler.com</a>
  20. muddysub
    Jun 23, 2001
    10,452
    489
    wow! thanks guys! lots of good ideas there. i think i'll use a die grinder, my friend has one it sounds easier. i like the idea of making a lip at the edge but i think i will go with flares. once again thanks alot!!
    scott,
