fender emblems
Discussion in 'The Garage' started by manu, Oct 8, 2005.
  1. manu
    manu Registered Member
    Jun 5, 2005
    5
    Netherland
    I just received fender emblems to be mounted onto a CUCV pick up truck ;
    Does any one know how to fix them ? The ones I received are original Chevy parts , but are sold without nuts or other locking stuff
    Thanks for your advice
    Manu
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I thought the newer ones glued or stuck on . like the chrome around the truck :dunno:
  3. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    if thay have the pins on the back go to a body shop supply store . thay will have the proper clips or nuts for ya.
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Yeh its those little cutter nuts(what i call em anyway), they hold on all sorts of trim around the truck. Only prob is you have to pull the fender to put em on :crazy: Screw that, when I replace mine im gonna glue em on;)
  5. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    Speed nuts are the proper name for them, you can get them at any Napa store..
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    THATS THE NAME!!!!!!! I could never remember it, so I just called em cutter nuts since they cut into the plastic studs.
  7. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    Speed nuts...
    They call them "pal" nuts too--but they suck!--90% of the time they snap the studs off the emblems!.(and they are a bitch to get at and tighten--unless you have the fender off the truck!)--.
    Most body shops here either use double faced 3M foam tape to stick them on,or use "Barrel Clips" that press into the hole from the outside--they have a flange to keep them from falling thru,and little "barbs" on the inside to grip the pins on the emblem..then all you have to do is press the emblem's pins into the holes with the barrel clips to install it--no ripping your hands up trying to reach those pal or speed nuts,or possibly breaking the studs off.. :doah: :crazy:
