fender triming time!
Discussion in 'The Garage' started by shaun89, Oct 16, 2005.
  1. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    i just picked up some 38.5x15 tires and im putting a 6" lift on, im not going for flexing beyond belief, and i no i have to trim a bit, any suggestions on how to keep it "stock" looking, how much to trim? anything? any tips will help a lot
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Take your time, make the curves smooth, mark it out beforehand, and don't use a sawzall except where absolutely neccessary. Mine are a little beyond stock looking so pictures probably woudn't be helpful. However, you are gonna have to take a decent amount off to clear those tires even without a really flexy rig.
    EDIT: Shaun :doah: I forgot to reply to your e-mail, my measurements were: ~ 3" from door seam to edge of fender in front, and ~ 4.5" from door seam to edge of fender in back.
  3. shaun89
    Aug 7, 2005
    1,942
    center of CT..ish
    ok thanks a lot man :bow:
  4. jolane
    jolane 1/2 ton status
    May 27, 2004
    132
    I have been thinking about trimming my fenders also. I am leaning towards doing a fender widening instead by cutting out and rewelding the factory fender lip. I figure I can section the lip to give me more height and width, and still make it look factory. This is on a decent looking burb, and I don't plan on rock crawling nor other extreme 4 wheeling.
    I don't know if you have the tools, skills, or desire, but this might be an option for you.
    Joshua
  5. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    To keep some what of the original opening you can make this cheap little tool.
    for however many inches bigger you want the opening to be just make a spacer that tall and tape it to the horizontal ruler. Then tape a pen or pencil and tape it to the spacer, and vert. ruler. ste the horizontal ruler flush with the opening and just trace around. I haven't tried it yet but i think it might work.. try it and let me know how it turns out..
