fender trimming? any advise?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by patrickcampbell, Aug 26, 2003.
  1. patrickcampbell
    patrickcampbell Registered Member
    Sep 11, 2002
    60
    I have a 7" lift front and 8" in the back and my 36x 12.5 tsl's are rubbing i figured i wouldnt need anymore lift so i need to trim the fenders. how is it done and and how do i cover up the cuts so it looks pretty? /forums/images/graemlins/crazy.gif /forums/images/graemlins/confused.gif
  2. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    I used a sawsall to make the rough cutts. Then a die grinder and sanding disc to get the corners I wanted and clean up the cut. You can see pictures of it in my webshots. /forums/images/graemlins/eek.gif Your probably not gonna cut that much off, so I would go with I die grinder to trim the corners were your tire rubs. Happy cutting /forums/images/graemlins/thumb.gif
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
  4. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Why did they cut out that much of the inner fender well? What did they use to fill that back in, the pics were kinda unclear to me. /forums/images/graemlins/crazy.gif
    Kris
  5. sapper
    Jul 11, 2001
    3,052
    NoVa
    you cut the inner so the tire can flex all the inside to the floor, just gives more travel. This is what i did on my first round of cutting, i didnt do anything to "finish" all it does is hang there anyway. I have seen people fold the edge or weld on a 1/2" rod to put in another inner but you dont have to.
  6. mud390
    Oct 31, 2002
    1,210
    What kind of abuse does the front of the tub take without the inner fender there?
    Kris
  7. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    Use a sawsall!
  8. sapper
    Jul 11, 2001
    3,052
    NoVa
    i guess that depends on how hard you drive it /forums/images/graemlins/thumb.gif, another option you have is to pull the inner fender out of the way, then do your cuts to the outer, after that beat the inner back to the outer and weld the seam
  9. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    i started with a sawsall, then bought a jigsaw, and imediatly went back to the sawsall. its easy to make straight cuts. buy some shorter blade if you can find them its much easier to use a short blade when their is metal behind where you are cutting. i used a hand held grinder to take any burs off. and a B.F.H. to beat the inner fender up
  10. sapper
    Jul 11, 2001
    3,052
    NoVa
    i like to use a cutoff wheel, easier to control and gives a straight cut, BE CAREFULL if you cut the driver side inner fender, the e brake cable is back there, you need to find it and move it out of the way of where your cutting, have fun /forums/images/graemlins/thumb.gif
  11. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Sapper
    I learned the hard way about the Ebrake.
    Almost got the through it before I realised...
    having your head in the wheel well on a slight driveway wouldn't be good right about now.
    It was a close one seriously... /forums/images/graemlins/eek.gif
    Heres my cuts... http://community.webshots.com/album/35776205wJWTyp
  12. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    I Agree on the cutoff wheel.
  13. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Kris
    Nothing 'filled' it back in, with 5" of lift and 40's it's common enough for the tire to rub the floorboard when it's stuffed. My fronts are trimmed that much, and I have the same lift and tire combo.
    Here is my rear trim done with a 5" cut-off disc and a sharpie marker/forums/images/graemlins/smile.gif
    http://community.webshots.com/photo/87068619/87068765hlNZzL
    Rene
  14. Erich_in_AZ
    Erich_in_AZ 1/2 ton status
    Mar 23, 2002
    237
    Tucson (it\'s a Dry heat), AZ
    Everyone here has missed the obvious! Plasma Cutters are the way to go! /forums/images/graemlins/grin.gif
  15. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
  16. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    [/ QUOTE ] <font color="green"> Yep, if you don't care about the paint then it is the way to go. Mine were done with a Plasma and they turned out real nice, just needed some cleaning up with a grinder afterwards. </font>
