Fender Trimming Tips
Discussion in 'The Garage' started by FL84K5, Jun 14, 2002.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    Time to pull out the sawsall and do some major fender trimming. I'm thinking like the trimming done of the UAV. Does anyone have any tips to do this?
  2. tRustyK5
    Jul 23, 2000
    36,184
    1,393
    E-town baby!
    Ear plugs and safety glasses...
    I marked my cut line with some masking tape and a sharpie marker, then cut through the masking tape. You could also make up a cardboard template so both sides turn out the same /forums/images/icons/smirk.gif
    rene
  3. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Buy a lot of saw blades. I went through a package of 15 Morse blades doing mine (well and my doors too...). I used the sawzall on the outer fender and bracing then a grinder on the inner fender, went through 3 grinding discs cutting the inner fender. I used a piece of cardboard and traced out the 1st side then copied it over so they are both at least close to being symmetrical. The tire clearance is amazing /forums/images/icons/shocked.gif
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Also, make sure the back side is clear. Otherwise you'll kink the blades. When (not if) you kink them, they can be straightened repeatedly with a pair of vice grips, but eventually they will break. I've done this (see pic below - along with cutting the bed, rear frame, and allot more) and I still have not used up a pack of 5 Milwaukee blades. Also, don’t force it and you don’t need to run wide open all the time (assuming variable speed). You’ll feel a “sweet spot” where it doesn’t beat you to death but still cuts relatively quickly. Stay there and the blades will last much longer. Also, you don’t have to make all the cuts at once, let the blade cool, if it gets too hot you’ll loose teeth much faster. Not generally a problem on sheet metal but worth mentioning.
    You’ll also need other tools to do it right. Shears, cut-off wheels, grinder, etc. come in very handy.
    And, yes, I’m currently enrolled in a 12 step program in order to get my addiction under control.
  5. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    on the drivers side be carefull when cutting the inner fenders because the e brake is hiding back there. i did my inners with a cut off wheel and it worked great. i then cut the outers with a sawsall and wish i had used the cutoff wheel. they keep the lines real striaght. it took me about a hour with a angle grinder to get the waves out. /forums/images/icons/mad.gif
  6. sapper
    Jul 11, 2001
    3,052
    NoVa
  7. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    Yep, Ive got the fendercut page book marked. The pics wil come in realy handy when I'm marking where to cut.
  8. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    i used a craftsman cut off wheel...it worked soooo much better than a saw zall...just put a few layers of masking tape on where you are goin to cut then draw your line on the tape...then get to cuttin...worked great...when threw about 5 discs but love the way it turned out...need to trim just a little more but...go for it! /forums/images/icons/grin.gif /forums/images/icons/grin.gif
  9. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I agree with Chaz, the cutoff wheel is the way to go. I don't think I even went through an entire wheel cutting both sides. It makes smooth STRAIGHT cuts and leaves no waves or ripples. I've cut my fenders front and rear and my half doors with it and I couldn't imagine getting such good results with a saw-zall.
  10. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    My vote is for the cut off wheel, too. I used a saws-all on the '80 (for the second go around) & a cut-off wheel on the '73. One more tip: buy a good die grinder not one of those cheep POS cut off tools. IR makes a good one but CP has one that is a lot nicer, about $90 either way. The rubber/plastic cover will keep your hand from freezing and the built in adjustable regulator is nice, too.
  11. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i marked the line i wanted cut and used a plasma-cutter /forums/images/icons/smile.gif worked awesome and very fast /forums/images/icons/smile.gif
  12. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    What are you using the cutoff whell attached to? Does anyone have a link with a pic so I know just what I'm looking for? Thanks
  13. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Use a torch, and then grind it smooth with an angle grinder, though the best way would be to use a plasma cutter. If you don't have access to one try your local High School's metal shop, or any Junior College's in your area, most welding instructors are glad for any outside projects that their students can do.
  14. tRustyK5
    Jul 23, 2000
    36,184
    1,393
    E-town baby!
    I'd have to say of all the ways to cut fenders the torch would be my last choice. (no offense) Between burning the paint, warping the steel from the heat and possibly setting other stuff on fire I would avoid the torch. Then you need to grind it smooth. You may as well use the grinder right away to cut em and save some headaches...
    Rene
  15. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    heh i dont think id let a Class of Highschoolers put their hands on my truck and be told to trim my fenders back,
  16. FL84K5
    Aug 19, 2001
    936
    Sarasota, FL
    A torch is out of the question. I don't have access to one anyways. I'll either use a cutoff wheel or a swasall for the main trimming. I'll be sure to post some pics when its done.
  17. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I've used the sawzal and cut-off wheel techniques. But for outer sheetmetal I prefer to use an air-saw with a small fine tooth blade. It is an even cleaner cut and leaves a finished edge. It is much harder to get a nice curve when cutting with the cut-off wheel. An air saw can get you in and around alot more things then the cut-off wheel (plus it is alot safer when it binds up compared to a cutt-off wheel)
  18. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
    I used a cut off wheel for my 4 1/2" angle grinder it tore right thru it like butter, didnt chip the paint, or tear it up in any way, just a nice smooth cut. Good luck.
  19. 74k5inVA
    74k5inVA 1/2 ton status
    Dec 13, 2001
    329
    Virginia Beach, VA
    awhile ago, somebody had put in a post a link to his site which gave pretty detailed instructions on how he trimmed his fenders. It started out something like measuring 6 inches from the back of the fender and snapping a straight line from that point on the bottom of the fender to the apex of the curve at the back of the wheel well. It was alot more in depth than that. It is probably what i will do whith my new fenders.
  20. 8BaLL
    8BaLL Registered Member
    Jun 13, 2002
    64
    Northwest Missouri
    I wouldnt mind seeing some detailed pictures of someone's fenders that have been trimmed. I can read and listen to people all day but for me to know what I am doing I need a pic. I am mainly wanting to see how the inside of the fenders are trimmed.
