Fender Trimming
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Russ, Jul 7, 2001.
  1. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Steve,
    I was wondering if you had any good close up pictures of how much cutting you had to do to keep those 37's from rubbing? I have a 90 Blazer that I am running 37" Boggers on a 6" National Spring lift and a 1" ORD body lift and even after cutting I still make pretty serious contact with the rear part of the front fenderwell. This is also after moving the front axle forward an inch when the springs were made. Thanks for the help.
    Russ
  2. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Russ, do you have any pics of your fenders currently, I would like to see them because I am thinking of running 37's but I don't know what size of lift I should put on. Thanks
    It's not what you buy, its what you build...
  3. tRustyK5
    Jul 23, 2000
    36,166
    1,364
    E-town baby!
    Russ, I run 36" TSL's with 5" of lift, no sway bar and they don't even come close to hitting. If your 37's hit you need to trim more...[​IMG] I patterned my trim after Steve's. I measured 6" from the front edge of the door and scribed a mark, then i used a flexible straight edge and drew a line up to almost the top of the fender arch and cut a ton of steel out of my front fenders...[​IMG] If you do it like this the inner fender will also need to be trimmed or bent rearwards and somehow fastened. i bent my inner fender back and tack welded it to the fender.
    Rene
  4. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    tRusty,
    Thanks for the info, I was trying to figure out how I would work the inner fender if I cut back that far. I also am not running a swaybar so it flexes a lot (right into the fender). I definitely have to keep my inner fenders now though as I just moved to Florida and it is a quite bit muddier here than it was in Southern California.
    Bullet- Sorry but I do not have any pictures and don't have a digital camera to take any yet.
    Russ
