Fender washer size?
Discussion in 'The Garage' started by 4X4HIGH, Dec 11, 2005.
  1. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Quick question, what size fender washers are people using to try and fix the D60 DW?
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I used 1/2" fender washers. 2" outside diameter, 1/2" hole in the middle and 1/16" thick. Got em at Homo depot...
    Worked like a charm.
    Rene
  3. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    They get used as shims to increase the king pin spring pre-load...which cures DW issues.
    Rene
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I couldn't wait for an answer so i went to Orchard Supply Hardware and bought some and low and behold, they are 1/2" x 2" fender washers and they actually measure .056" thick. Before i took the cap off i removed my tie rod on the driver side and measured the amount of torque it took to move the steering knuckle and then did this again after i installed the fender washer and the required torque increased by 5 lbs. I did the same thing with the passenger side knuckle but had to also remove the drag link as well as the tie rod and once i was done installing a fender washer there was no change at all on the required torque so i'm going to guess that i will still have DW and it will be from the passenger side and i will have to add another washer to that side.
    Wish me luck, i'm about to go drive it and see what happens.
  6. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    I wonder if your torque readings with the weight of the vehicle off the axle are really an indication of how it will run with the weight on it :confused:
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    This how how GM says to check for ball joint preload and also king pin preload.
