Few issues with my 14ff swap
Discussion in 'The Garage' started by 73K5Kid, Mar 20, 2007.
  1. 73K5Kid
    73K5Kid 1/2 ton status
    Sep 24, 2002
    583
    chandler az
    I used a 77 14 bolt swap out of a suburban. Main problem I had was that my drivers side shock would not mount up to the 14 bolt bracket. I was going to cut the bracket and reweld it thanks ( aka Shawn Supersize75k5). I ended up fliping my shocks and had to remove the metal insert on the shock where the shock mounts up top. It works pretty good :D I will post some pics later. Also had issues with brake lines I had to use the set off of the 14sf cuz the 77 line was not long enough to mount to the top mount brake line. I still have address ebrake lines those are differnt to :rolleyes: After swapping in the 14 ff by myself the ebrake can wait :doah:
  2. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    there's always something that's causes a setback. gotta expect that when modifying anything.
