Few ??? on getting a cucv on the road again
Discussion in '1982-Present GM Diesel' started by 84CUCV, Dec 16, 2005.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Hi, guys its been a while since i have been here. Anyway, time to put her back on the road. So far i am changing the fluids, just not the diffs. I will have my 14 and 60 ready soon i hope. Last thing done was a rebuilt pump. DB2 i think, been while since i looked. I have a block heater ready to go and i going to get one of the newer starters off ebay after i go to a all 12v system. What is the website that shows how to do that? What batteries should i go for? the ones in there are 5-6 years old. Here is what she really needs. Anyone, know of a way to bypass the system on cucvs for the gp?? mine has been alot of trouble as you my know. posted a lot on that. i was thinking a manual setup would be the best for me anyway.
    As always thanks guys
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Fully manual glow plugs or just a manual assist? both are pretty easy to do, but better to start giving info to help you in the right direction.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Fully manual glow plugs sound like the way to go for this truck. i have no other idea what to do with the way the military has it. thx mike
  4. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    If you're replacing the starter (for a 12V), you're half way there. Wire the batteries parallel (instead of series). IIRC the power (24V) goes to the bus bar on the firewall. Remove/bypass the ballast resistors (behing the air cleaner on firewall). Replace glowplugs with a good 12V style. GM took 24V and reduced it to 12V 'cause of the high amp draw of the glow plugs. 24V is the standard for military vehicles (to slave "jump start" one another) and to power mil spec radios.
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    I have no idea how to Wire the batteries parallel. I know very little about wiring.
  6. rivermtnman
    rivermtnman 1/2 ton status
    Nov 7, 2003
    102
    Lebanon, VA
    Check out this:
    www.roscommonequipmentcenter.com/news_notes/nn10.pdf
  7. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
  8. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thanks for the link guys. So, can someone help me with my GP problem?? thanks mike
  9. rivermtnman
    Nov 7, 2003
    102
    Lebanon, VA
    NP Mike, thanks for making it "clicky" Rene, thought I did it right. Can't help with gp as I'm having trouble with mine right now also. I'll let you know what I do with mine, but am planning right now with staying 24 volts. SSDiesel is telling me I'm using the wrong gp's in it.
  10. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    I think mine are 9gs or something like that. I am going to get some from kennady diesel. They dont burn out or mushroom. please let me know if i am wrong.
    I think i am going to 12v.
    mike
  11. rivermtnman
    Nov 7, 2003
    102
    Lebanon, VA
    Well, I took 3 of 4 Kennedy's down with 2 startups. Apparently the 60g's take the overvoltage alot better than the kennedy's, since i've had 4 of them still in truck for over a year. And 3 Autolites lasted almost a year. But from what I'm being told I'm using the wrong plugs....
  12. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    really?? i thought Kennedy's where good plugs. Maybe 9gs would work for you??
  13. rivermtnman
    Nov 7, 2003
    102
    Lebanon, VA
    Remember SSDiesel is telling me I'm using 12v plugs in a 24v system, and that I'll burn them up instantly(which is what happened with the kennedy's). I just found in the military manual that this truck called for a 13g's, not sure what voltage their rated at. Also remember I may have some other problem that I've not found yet. I know I don't want to start it again until I figure it out, lol. It will probably snow 2' deep while its down. Won't that be just my luck.
  14. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    yea thats would suck. 13gs i think are 12v from what i remember.
  15. rivermtnman
    Nov 7, 2003
    102
    Lebanon, VA
    OK, after reading some older post from DieselDan, I know my system is working properly, because its supposed to have 24v until the solenoid kicks on and it drops to 12v. For my application, I'd advise to stay away from the kennedys, unless they sell something military specific. SSDiesel does, but I'm probably gonna stick with 13g's or maybe put 60g's back in it, since thats what came out of it. Just feel I shot $80 for kennedy's for 2 start ups for nothing. Expensive lesson. And I'm not 100% sure of agreeing with email answer I got back from SSDiesel. My truck is easier to start than my gassers at 0* (as long as I have 8 working glow plugs), and I have no block heater.
  16. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Block heater is something i should do too. Forgot about that. Guess i will try some 60gs ans see how it goes. thx
