Few questions about pulling an engine
Discussion in 'The Garage' started by jarheadk5, Apr 25, 2006.
  1. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    This is my first automotive engine removal experience, so please bear with my silly questions... I'm pulling a 6.2 from a C10 to install (eventually) in my K5.
    - How many bolts are on a 700R4 bellhousing?
    - How many bolts are on the diesel torque converter?
    - Is it easier to pull the engine & trans out together, then separate them on the ground? It's a 2wd 700R4, so there's no T-case to worry about...
  2. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    I have never pulled that exact combo, but if I have the choice, I prefer to pull the engine and tranny together...it is hard (not impossible, just a PITA) to reach all the bellhousing bolts. The downside is that the engine and the tranny togehter can be kind of big, heavy and awkward, having buddy help makes it much much easier...
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I believe there are 6 3/8" bolts for the bellhousing.
    Heres a good trick for pulling them EASILY.
    Get about 4' worth of extensions for your ratchet and get a 9/16" wabble socket.
    Can get all the bolts out in about 5 minutes:D
  4. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    theres always 6 bellhousing bolts on a GM regardless of engine, RWD anyways
    yep really long extension and universal joint and short socket 9/16" will get them out, and a good light source under there too
    GM converters have three bolts to the flexplate
  5. jarheadk5
    Mar 6, 2000
    4,389
    PA
    OK, cool.
    Now to decide which way to do the deed...
  6. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    um...
    Some diesel and HD gas torque converters have 6 bolts to the flexplate...:wink1: --I've only seen one on a 292 six..never had to look at my diesel one,hope I never do!..
    I'd pull both at once and separate them on the ground...much easier!..:crazy:
  7. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I've heard the diesel TC's are held with 6 bolts too. I'd separate the motor and tranny...less mess, less hassle (IMO) and it's just a ton easier to get the motor out. If the donor is not going back together I'd even consider removing the front clip, that's a lot of motor to try and get over top of the core support.
    Rene
  8. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Front clip on the C10 is totally removed, just finished that on Tuesday. I gotta take a couple pics of the frame where the steering box goes - it's freakin' TRASHED.
  9. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I believe the factory manuals say motor and tranny together for cars, engine alone for trucks. Helps to take off the front wheels and set it down on the ground too.
    Or, stripped to the frame, like yours, I'd pull the engine and trans just cause thats the easy way get the trans.
  10. jarheadk5
    Mar 6, 2000
    4,389
    PA
    It's out!
    Engine & trans came out together today. Stand-by for pics and narrative...
  11. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Cool!! Any surprises?
    Rene
  12. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Couple small things. I'm writing a new post with pics right now...
