Few questions on assembling a 350.
Discussion in 'The Garage' started by y5mgisi, Nov 22, 2006.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    I Just got my heads back from the shop and i need to know a couple things. First should i use loctite or anti-sieze on the head bolts? Second does anyone have the torque specs for the rod bolts and main bearing bolts? I also need torque specs on the head bolts them selves now that i think of it. I need help. I want to finish assembly tonight!
  2. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    i always use rtv on sbc head bolts. They feed directly into a water jacket. Ultra black is what i use. in storage is my sbc book, just get a book for 15 dollars, it tells you damn near everything.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you don't want loctite or anti-sieze on the hed bolts, but a thread sealer as they thread into the waterjacket in the block. i have always used teflon tape without a problem but i have heard it can have an affect on the torque specs.
    can't think of the torque specs off the top of my head, but i think the rod caps are 45 ft/lbs.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I only use a drop of oil on each head bolt. Make sure that the head bolts are clean and also that the holes in the block are clean.
    Head bolts = 65 ft. lbs.
    Main bolts = 70 ft. lbs.
    Rod bolts = 45 ft. lbs.
  5. bronc3buster842001
    bronc3buster842001 1/2 ton status
    Sep 30, 2006
    1,996
    6
    leadwood missouri
    need to know year and if its a four or two bolt main i got the specs somewhere just got to find them
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Year doesn't matter and either does 2 or 4 bolt. I do this for a living every day. Trust me on this.
  7. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    I do as Scott mentioned. Clean bolts and holes, just oil on threads.. ensures proper torque... I've probably done a hundred sets of heads, never used a sealant and never had an issue...
  8. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    got it. Cool thanks guys!
  9. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    Ive never used oil or sealant on any of mine. in fact Ive never heard of it being done. never had any problems either.
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i thought the outside bolts on the 4 bolt were like 5 ft/lbs less? so it would be 70 for inside bolts and 65 for outside bolts. is this right? its what my haynes manual says.
  11. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    True, but you can put them all at 70 ft. lbs. won't hurt a thing.
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    with the exception of the main bore, that is, unless your machinist screwed up just like you did.
  13. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I have been building engines for 20 years PROFESSIONALY and 70 ft. lbs. is an acceptable torque value for a 4 bolt block. It will not distort the main bores like you're thinking it will.
    So Beater_K20, which book should i scan for you?
    My 1971-1978 Chiltons book says main bolt torque 70 ft. lbs.
    My 1979-1986 Chiltons book says main bolt torque 70 ft. lbs.
    My 1986-1990 Chiltons says 2,3,4 bolts 70 ft. lbs. other bolts 80 ft. lbs.
  14. MaxPF
    MaxPF 1/2 ton status
    Apr 13, 2006
    2,207
    Chandler, Arizona
    According to the Chevy power manual when assembling a production block you are supposed to use a thread sealant on the head bolts, since they thread into the water jacket. Not doing so invites the possibility of your new motor losing water and gaining oil :doah:. The only time you don't need to use sealant is if the block has blind-tapped holes (the holes don't penetrate into the water jacket) - AFAIK no production block is blind-tapped, only Bowtie blocks and some aftermarket blocks are that way. In the holes are blind tapped, use 30wt oil instead of sealant.
  15. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    don't rush anything dude. make sure you plastiguage everything possible to make sure your clearances are right. it was real helpful to me to have some assembly lube in an aerosol can for getting everything lubed up right. my situation was a bit different, b/c it's diesel, so i won't add much on putting it together, but the instructions above all seem real close to what i did.
