Few simple questions
Discussion in 'The Garage' started by stockk5, Jan 28, 2006.
  1. stockk5
    Apr 13, 2004
    2,037
    73
    Cromwell, CT
    Well i finally pulled the motor im getting outta the truck it was in. A 350 crate w/ 30,000 on it, it has a high rise intake w/ holley carb on it right now. My 305 is TBI, when i was planning this swap a few months ago i kept reading in need new injectors and a computer and knock sensor. Other than those three what do i need? Also is this the computer and will my 305 stuff plug into it? (sry not to familar w/ engine components)
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    that is the MAP sensor, the computer should be in an unfinished metal case about 4 1/2" X 7" try doing a search, a lot as been covered on this swap
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    in the pic, the think on the left is the ESC module you will need a new one of these from a 350, they are calabrated for the desplacement of the motor. the other thing is the map sensor, i believe this is the same between 305 and 350, i know it is for a 4.3 and a 350.
    the computer that you need to change is behind the glovebox ontop on the heater core box. you can use the same computer and just change the chip, but you need a chip from the same style computer with the same style chip. if you have no clue what i mean, just get a computer from a 350 that has the same service numbers and change the whole thing. the knock sensor off a TBI 4.3 is the same as a TBI 350, so if your junkyard hunting and can't find one off a 350, a 4.3 is the same.
