ff14 bolt modifications
Discussion in 'The Garage' started by gmcsrgr8, May 15, 2002.
  1. gmcsrgr8
    gmcsrgr8 Registered Member
    May 3, 2002
    12
    Utah
    I just shaved my rearend! Boy it sure itches now. I think my aftershave sucks, or my razor was dull.(kidding) Here is my question. Before I bolt this up to my jimmy, I want to make sure that I get everything done right. Shaving that was pretty fun and now I want to know about the shock brackets. How hard or easy is it to move, or make new brackets that are on top of the axle tube. and is it even worth the effort.Any and all comments are greatly appreciated. Thanks all
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Very easy to do.
    Just get a plasma cutter and cut them off to relocate them up higher on the tubes. /forums/images/icons/wink.gif
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I torched off the origionals and made some <a target="_blank" href=http://community.webshots.com/photo/34634137/34633035NSGOlk>new ones</a> .How much did ya shave off the bottom?
  4. gmcsrgr8
    May 3, 2002
    12
    Utah
    I'm not sure if I am done shaving it yet, but so far I have cut the lip off from the base of the dif. cover. It is now a smooth angle and there are no edges that hang down anywhere. I plan on adding an Avalanche Eng. rock ring and I don't know if I want to modify either that or the dif. cover by shaving more off, so I may be done grinding. At least I removed that lip.
