FI- what year did it start?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nonesuch, Oct 23, 2001.
  1. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    simple and easy...which year K5 was TBI introduced?
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I believe 87 was the first year for TBI in all chevy trucks.
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  3. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Correct...1987 across the board.
    The learning curve is a toll road...ride with someone who has already paid!
    <a target="_blank" href=http://photos.yahoo.com/abshort1>My Naval Fleet</a>
  4. ArrowheadK5
    ArrowheadK5 1/2 ton status
    Aug 3, 2001
    252
    Northern MN
    so EFI was started the same year?? Why did they come out with 2 diff FIs in the same year? is one better?
    Four wheel drive, four wheel expenses...
  5. chevrules
    chevrules 1/2 ton status
    Aug 26, 2001
    127
    Canada
    87 was first year for the K5
    chevrules...always has and always will
  6. dyeager535
    26,979
    EFI=Electronic Fuel Injection. TPI and TBI both meet that criteria.
    Assuming you are wondering why they had TPI and TBI, partly because of emissions I am sure (cars got TPI for the most part, trucks all TBI then, probably ALL emisssions) as well, the performance and likely clearance issues of the ever smaller underhood clearance of the cars.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  7. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    I think that the biggest reason that TPI didn't make it into the trucks was the cost. Would have been sweet though, they make great torque.
    '85 K5 : Run it til it breaks, then fix it and go again!
  8. dyeager535
    26,979
    You're answer is much better than mine : )
    Dorian
  9. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Are you talking about 1-3 lbs./ft. of difference from 2-3K rpms ?
  10. dyeager535
    26,979
    Think you added a one, and forgot a zero www.dorianyeager.com/index2.html
  11. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Food for thought.................
    Its not really fair to compair the TBI and TPI. and say the TPI is better because it makes more power on paper.
    .Even though they were both 350s. The TPI and the TBI engines were mechanically completly different from each other.
    One thing you have to concider when comparing TBI trucks to the TPI in the cars is that the TBI 350 engines were only 8.2 :1 compression ratio.
    The ones in the 350 TPI cars were 9.3 :1&amp; 9.5 :1 Cr. They also ran different cams. That alone will boost the power and torque quite a bit.
    Boost the compression ratio up to 9.5 :1 and put in a better cam and I bet the TBI specs would come very close to the TPI.
    [​IMG]Sometimes nothing's simple and easy on this board.[​IMG]
    <font color=blue>NEVADA: Where the pavement ends, and the West begins.</font color=blue><P ID="edit"><FONT class="small">Edited by Thunder on 10/24/01 05:29 PM.</FONT></P>
  12. dyeager535
    26,979
    Thats true, cams would have changed. But same year TBI/TPI, same sise motor, same vehicle, both hp/tq were 30 more for TPI. And thats having to meet the same emissions standards, so the motor/vehicle was somehow getting more power while still meeting the same standards. Thats of course assuming running at the ragged edge of "acceptable" emissions. (ASSuME)( Very well could be much better, but that costs money, and GM spending money when they don't HAVE to, well. : )
    Dorian
