fiberglass/cowl induction hood
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jsck5, Jun 15, 2001.
  1. jsck5
    jsck5 Registered Member
    Apr 8, 2000
    12
    I just bought a used cowl hood that was on a 86 k5 for my 87 k5. i put it on for a test fit and i notice that its arched or bowed, i think, the sides are taller than the fenders. not only that but the latch is a different design so that really sucks. some people tell me its for a different body stiyle thats why its not flush with the fenders and the latch is differnt, but it fit fine on an 86. im not sure if any one can help me on this but i just like bitching about it cuse this really really sucks, I wanted a cowl hood waaaaaaaaaaaa!
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    86 and 87 are exactly the same to my knowledge. Try laying it upside-down in the sun for a while, and see if that takes the bow out. Why not just ditch the latch and pin it? It would probably be more secure at any rate.
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  3. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I think JC Whitney sells a little brace kit to fix this problem on the steel (factory) hoods. The pins may not be a bad idea either, I just put pins in my stock hood since I could never get the dang thing open.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  4. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    I run a Harwood cowl induction hood and it would be bowed too if I didn't remove my hood springs. You can rotate the springs so that you have very little tension to lift the hood. If you don't lessen the tension, the hood will bow for sure. My guess is that the last owner didn't remove or rotate the hood springs. I use very little tension on mine.
    87 K5, D60 & 14FF, 5 sp & NP208 & 383 stroker. Build it Bulletproof and take it fishing!
  5. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    ya thats right, i removed the springs completely on my 1990k5 and just pinned my fiberglass hood--no problems.
  6. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Unfortunately, 'glass hoods are notorious for bending like that. The sun does that alot. I had one on a '69 Camaro that drove me nuts. You may be able to straighten it out and maybe add some kind of reinforcements on the sides, but on alot that are already severly bowed you can't really do much.
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    If it isn't permanently bowed from the warping/heat, you can buy 'light' springs to replace the stock monster ones..........had to do this on my '71 Camaro when I put on a fiberglass cowl induction hood and it solved the problem. Probably the springs holding up the hood. Take the stock ones off and see if that solves your problem.
    Source for the springs? Not sure, but try Harwood.
    <font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.alloffroad.com>http://www.blazzinor.alloffroad.com</A>
  8. xtreme_wlr
    xtreme_wlr 1/2 ton status
    Mar 22, 2001
    103
    San Diego, CA
    I run a fiberglass drop-center hood. I dont use springs on it and pin the front. Pics of it somewhere on my site, just too lazy to find em :)
    Oh yeah, no problems with it bowing without the springs.
    78 Chevy 1 ton Stepside RockCrawler
    468 BB, SM465, NP205
    D60 front, GM 14Bolt w/ Detroit
    <A target="_blank" HREF=http://www.bowtiecrawler.com>http://www.bowtiecrawler.com</A>
    <P ID="edit"><FONT SIZE=-1>Edited by xtreme_wlr on 06/15/01 08:55 PM (server time).</FONT></P>
