fiberglass on the floor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stickshooter, Oct 26, 2001.
  1. stickshooter
    stickshooter Registered Member
    Oct 26, 2001
    23
    Has anyone used fiberglass to patch holes in the floorboard? Is this a bad idea? It seems like some minor holes in some non critical areas could be glassed and painted much easier that cutting out the whole floor and welding in a new one.
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I had a body guy tell me when I was trying to fix mine to use fiberglass. I twill never rust and will work in non critical areas. I would work under seats too if you braced it properly.
    My .02
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  3. ironmikek5
    ironmikek5 1/2 ton status
    May 31, 2001
    145
    Massachusetts
    I've used it on some minor holes with great results, I ground down the rusted metal, fiberglassed the hole, POR-15'd the good metal around the hole to prevent rust, and painted the fiberglass black to match. You can barely tell it is there, and two winters with no additional rust in those spots.
    <font color=red>I will not tolerate intolerance </font color=red>[​IMG]
