Fiberglass or sheetmetal?
Discussion in 'The Garage' started by sled_dog, Feb 20, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Well thinking about what I'm gonna skin the buggy with when I get to that point. I've seen custom fiberglass work on those ricer shows for their speaker boxes and all, doesn't look hard. Simple wire mesh backing formed to your shape, lay the fibgerglass mat, layer it up and let it harden. My only concern is, which do you think will be lighter, some good layered fiberglass or some pretty thin sheetmetal riveted on. With fibgerglass I could make fenders/hood one easily removed piece. Body flex shouldn't be much of an issue since its a tube chassis. I figure as long as fibgerglass isn't right in front of the tires mud and rock path(where it would be hit) it would hold up.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I would do the sheetmetal thing. You're going to have flex, tube buggy or not, and it will fatigue and crack eventually.
  3. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    Sheet Metal, as it is easier to replace a panel than patch one!
    Bill
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I would do sheetmetal for the firewall, floor, skids. For the rest you could make Lexan body panels.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    floor will probably be steel grating, just for tread factor. Firewall will definetally be sheetmetal, as well as the tranny tunnel. I will probably bounce off some rocks and trees so sheet is much easier to replace. Hmmm. As far as lexan, it owuld be nice, but it would make me angry when it got muddy and I couldn't see through it /forums/images/graemlins/smile.gif, even if you can never see through sheet.
