Figure out My splines?
Discussion in 'The Garage' started by broncoman6524, Apr 12, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    Im trying to figure out what gears i need for my axles (i think im gonna go with 4.11s) But i dont know whrether my axles have 28 or 30 splines.
    From the factory it was a k5, 305/700r4, 10 bolts w/3.08
    i now run a 350 soon to be 383 th400 and still 10 bolts w/3.08s
    my question is would this be a good gear ratio and how do i figure out what splines i have?
    thnx
  2. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    What year truck
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If your rig is an 84 it will have 28 spline unless someone has changed it to 30. If you install a 400 you're losing the OD so i would say that 4.11's would be a good choice but that depends on what size tire you're running.
  4. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    GM went to 30 spline in 88. everything earlier was 28 factory.
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Actually 30 spline started in 1989.
  6. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    what ever, 88, 89 they were both crappy years :D
  7. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    From what i've heard the 28 splines are stronger than the 30 splines in the fact that in order to increase the spline count from 28-30 the carrier was bored larger which means less material in the critical area. Doesn't matter to me anyways since i'm running 1 ton stuff under my rig but for those with stock 1/2 ton stuff they may want to know. :thumb:
  8. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    ive never heard that. 30 spline is obviously a hair larger, and theoretically stronger, but your arguement is probably valid too. doesnt matter for me either, ive got a 60/14 too.
  9. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    Hey now, I've got an '88!!! :mad:
    j/k I've had my fair share of problems with it.
    2 trannies and the rear axle went out, but that couldn't have had anything to do with the way I drive. :D
    It is running strong now. :D
    Rick
  10. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    Cracked Heads, Every Valve Rotten, Oil Leaks, Engine Ticks
    ive got an 85 K5, i would know
  11. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    :haha: :haha: :haha: :haha: :haha:
    I haven't heard that one before.
    Rick
  12. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    ya its an 84 and i've already got the 400 in after a month i needed a new tranny...bought it thinkin it needed a new trans pan seal... NOT :rolleyes:
    So 4.11's would be good gears for a truck runnin 33 A/t and mostly sees mud and sand?
  13. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    yeah. with an OD tranny you would want deeper, but you will be fine with a 400.
