figuring gear ratios
Discussion in 'The Garage' started by darkshadow, Dec 26, 2003.
  1. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    what is the easyest way to find your gear ratio out? THe wayi know is to mark the axle and turn the drive shaft and count the # of turns and calculate the ratio. IS there an easyer way? is it punched any where? /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif thanks guysa and gals /forums/images/graemlins/pimp1.gif
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    pull the cover, on your ring gear, if its original GM, will be a series of numbers, 2 of wich can be (for example): 41 11, 41 being the number of ring gear teeth and 11 being the number of pinion gear teeth, 41 divided by 11=3.73... /forums/images/graemlins/thumb.gif
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    My K5 had a metel tag with the gear ratio stamped on it. It was attached to one on the bolts for the diff. cover. Who knows, you might get lucky and find one on yours too. /forums/images/graemlins/tongue.gif
  4. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    cool thanks guys, i figured it would be in ther some ware but dident want to go in with out knowing where to look /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
