figuring out a shackle flip
Discussion in 'OffRoad Design' started by 90BCk5, Oct 16, 2005.
  1. 90BCk5
    90BCk5 1/2 ton status
    Apr 8, 2005
    278
    British Columbia
    alright fellas, heres my dillema i hope someone can lend me a helping hand. ive tried searching for the awnser to my Q but have not been able to find it.
    ok... so its a 90 blazer, with a D60 front and 14 bolt rear. i have 38.5's and a 6" leaf in the front and 6" leaf in the rear, shes sitting a bit lower in the rear and its pissiing me off, i know that the rear wheels wells are cut smaller than the front, but the rear pinon angle could use a bit of help.... could i use the 2.5" shackle flip in addiition to the 6" springs to get a bit more height? does it actually add up to 8.5 inches of lift? is that the way it works? also i know the fenders are out 2.5 " front to rear, but when i look at it from the side the roof is whats slanted.....
    thanks very much
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    If its just a little lower in the rear, get a set of zero rates. They are simple and give you a 1" boost.
  3. monster man
    monster man 1/2 ton status
    Oct 20, 2003
    282
    Reno, NV
    yes- it will add up to 8.5" if you use both together
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup, you can use the 2.5 flip for what you're talking about. Best way to check the height is to measure the bedrail or the body line for level. Jack the truck up by the diff to level it, then check how much you jacked it up and that's how much more block/flip/spring you need.
