file transfers?
Discussion in 'The Lounge' started by MTChevy, Jul 24, 2006.
  1. MTChevy
    MTChevy 3/4 ton status Premium Member
    May 6, 2005
    7,141
    78
    Great Falls, MT
    I got a whooole craplad of files I want to get over to my lap top but dont have any blank CD's or a jumpdrive or anything like that. Any suggestions on how to transfer em over? thanks.
  2. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
  3. MTChevy
    May 6, 2005
    7,141
    78
    Great Falls, MT
    wow i think my brain just short circuited:eek1:
  4. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
  5. MTChevy
    May 6, 2005
    7,141
    78
    Great Falls, MT
    is that an ethernet cable basically? I got one of them, can i use it?
  6. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Basically the same thing but one of te RJ45 connectors is wired differently. You could make one though
  7. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    I'ts an ethernet cable that's been wired up differently (in a crossover format - see first link) Basically what it does is let you hook 2 computers up and bypass the need for a hub between the computers. With that specialty cable, you can hook 2 computers directly together with that cable and it's just like they're networked on a hub.
    Clear as mud? :D
  8. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    I am planning on updating one of the PC's here in my office also,,the primary drive is too small (9.7 gig) that is loaded with data and files...
    I would like to put dual 80 gig drives in it ( remove the OEM drive and install 2 new drives )and use norton ghost to mirror the drives.
    Could I save the exsisting primary drives data onto another PC by using a crossover cable ??
  9. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    You can also use one of these. It's basically a USB cable with the same end on each side. I believe it's called a USB transfer cable. It's kind of slow though.
  10. MTChevy
    May 6, 2005
    7,141
    78
    Great Falls, MT
    whats a firewire? looks to be the same?
  11. ARAMP1
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    I believe firewire has a different type plug. This is just the standard USB ends. Connect one to each of the computer and you can transfer files.
    Click Here.
  12. 1BadK-30
    1BadK-30 1/2 ton status
    Feb 6, 2005
    817
    Phoenix, Arizona
    this is what a firewire looks like
