Fill me in
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jimmyjack, Dec 28, 2001.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I found a D44 and a matching 12 bolt from a 77 blazer today. The guy wants 200 for the pair. Open diffs, but he doesn't know the gear ratio. How much does a D44 differ from a 10 bolt? Are they beefier? Bigger? What gives? I've never had a prob with my front and I dunno if he'll seperate the pair. Is it possible to tell the gear ratio with out pulling the cover? Like spinning the axle and comparing it to the pinion or are the ratios to close to bother?
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  2. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Also if I buy this D44 will my steering parts match up or will I need to get new stuff?
    Jim
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    10's and 44's in the most part are the same, axle shafts differ by I think an 1" but other then that they are the same, as far as strenght. The steering parts are all the same.
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  4. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Anyone have any thoughts as to IDing the gear ratio without pulling the cover? I was going to mark the axle and the pinion and count revolutions that way or am I wasting my time?
    Jim
  5. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    Mark your pinion position on your shaft and rotate one tire 1 time count how many time the pinion makes a full rotation. make sure the opposite tire is on the ground if open diff.
    1982 K10 Silverado. [​IMG] 327 SHPE powerplant SM465/205,15"custom lift 38.5"TSL/SWAMPERS 12boltrearD44 front,3.73 gears.
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Look for a tag on the front D44 cover at the bottom corner. There should be a tag there and it will tell you what gear ratio you have.
    Check for this tag first. If it's missing, the BEST way to tell the ratio would be to pop the cover off and look for the numbers stamped on the ring gear.
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
