Fill plug on a 203?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MaxCrack, Jul 8, 2002.
  1. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    Where the heck is it? For that matter, where is the drain plug?
  2. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    the drain plug('s) is the bottom two bolts on the cover facing the back of the truck behind the front output shaft
    /forums/images/icons/wink.gif pull the bolts and it will drain. when you put them back in use some type of sealer rtv or whatever on the thread or it will leak
  3. MaxCrack
    Apr 10, 2001
    895
    Mt View, CA
    Heh, I almost pulled those before I left Wednesday night, but I was in a hurry and did not know where to put oil in. Still don't. heheh, unless it's a couple cover bolts higher up. /forums/images/icons/smirk.gif
  4. Redfrog
    May 4, 2001
    753
    IL
    this should help /forums/images/icons/laugh.gif
  5. MaxCrack
    Apr 10, 2001
    895
    Mt View, CA
    Should help? Unless I'm an idiot that will do nicely. Thanks a lot. Now I just have to get it home. heheh
    That leaves no questions
    Thanks,
    Mike
