Fill plug replacement for 10 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rampage, Jan 21, 2002.
  1. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    I've had it with the fill plug for my rear 10 bolt.[​IMG] It's starting to round out on the inside and I'm afraid that one day I won't be able to remove it. Does anyone know what size and thread pitch it is (sort of looks like a metric size)? I would like to replace it with a hex bolt. TIA
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I would pull the plug and go to Home Depot or a good hardware store. Thread it into some nuts until you get a match and you will know the size. Then, get you a good brass or socket head plug and all will be cool. I would be cautious about anything that would stick through the depth of the housing much like a bolt.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  3. rampage
    Mar 20, 2001
    2,261
    73
    I'll be cutting the bolt so it won't protrud into the housing.
    I thought about matching plug, but since this is my only means of transportation, I was hoping someone knew off the top of their head. [​IMG]
  4. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    Is it threaded in to the cast housing or the cover? If it's in the cast housing it should just be 1/2 NPT. I would get the plug from NAPA. They have higer quality pipe fittings than Home Depot. If it's in the cover try the dealer.
    '70 K-20 San Diego, CA
    I know, I can't spell!
  5. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    Is it threaded in to the cast housing or the cover? If it's in the cast housing it should just be 1/2 NPT, if by chance 1/2" NPT is too big it wouldn't be smaller than 3/8" NPT. I would get the plug from NAPA. They have higer quality pipe fittings than Home Depot. If it's in the cover try the dealer.
  6. rampage
    Mar 20, 2001
    2,261
    73
    It's on the housing but larger than 1/2. It's more like 3/4 but the NC and NF nuts I tried wouldn't fit, that's why I'm thinking it's metric. I may just end up taking tx85gmcguy's advice and pulling the plug in the parking lot and be done with it ...
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Get a small bolt which has a threaded end that fits snugly into the square hole on the fill plug, and weld it on there, or have someone weld it there. a muffler shop will do it for like $3. Now you can use a normal socket to get it out, and its a lot easier. This is what I did, and it works great.
    90K5
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It's 1/2" NPT. Just get one at Autozone.
    Tim
  9. rampage
    Mar 20, 2001
    2,261
    73
    Pipe thread ... DUH! [​IMG]
