filler neck for 71 blazer
Discussion in 'Parts & Trucks Wanted' started by 68MUDSTUD, May 2, 2007.
  1. 68MUDSTUD
    68MUDSTUD OCD with shiny things
    Sep 30, 2005
    9,448
    MT
    i need the piece that clamps onto the actual tank, should have a 90 in ti and mabe a 45 degree angle. Ive tried everything now, and im getting fed up with it.
  2. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,239
    284
    San Jose, California
    I have one still on my stock 71 tank. You mean the metal tube right? Mine is soldered onto the tank so it would need to be "un-soldered".
    Since I'm not planning on taking a torch near an old gas tank! :eek1: , I could cut out a section and send it to you that way? (I can fill it with water while cutting with a sawzall.
    If you have a new metal tank you can try bending the short neck one direction or the other to get a rubber fill tube on it. That's what I did except I used the plastic tank. Works pretty well.
  3. 68MUDSTUD
    Sep 30, 2005
    9,448
    MT
    oright, this is what i need....
  4. bp71k5
    Mar 31, 2006
    6,239
    284
    Oh, I see. If you just need the rubber hose, you can get that most anywhere. I thought you needed the metal part.
    I bought mine from here. It's just straight fuel hose though.
    http://www.truckandcarshop.com/
  5. 68MUDSTUD
    Sep 30, 2005
    9,448
    MT
    thanks man!!!!!!!!!!
