filling a rear end with gear oil???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RESTORE89, Feb 8, 2002.
  1. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    i feel kind of stupid asking this, but how do i put the gear oil in the rear end now that i have it back together. my diff cover has no fill plug. do i just pour it through the vent tube? if so
    how do i tell if i have enough in? what is the best oil for a hot climate, and should i use
    an additive, and what weight and brand of oil should i use with the lockright locker
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  2. Liberator
    Liberator 1/2 ton status
    Jul 16, 2001
    276
    Communist California
    There should be a plug on the side of the housing. It's recessed and easy to miss. Look on the passenger side infront of the axle tube. I think!
    Bo
    If it breaks, it wasn't good enough!
    http://coloradok5.com/gallery/liberator
  3. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    Your parts store should have a pump that goes on the one gallon jugs of gear oil. It usually cost under $10, and makes filling the rear end much easier and quicker.
    1989 K5
  4. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    yep
    thats where it is, i just went and checked, and low and behold it was stareing right at me
    i assume this is the fill level also!
    to bad all my K5 problems arent this easy to solve
    i love having the computer in my shop, the only way this could be better would be to have a laptop under the truck LOL
    thanks
    what's in it now?
  5. Liberator
    Jul 16, 2001
    276
    You should be able to use the standard 80/90w with the locker. I don't use any additives, just the oil.
    Bo
