Filling a tapped hole
Discussion in 'The Garage' started by adamforsythe, Oct 31, 2004.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    How can I fill a drilled and tapped hole?
    Thank
    Adam
  2. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    What is it in? Plate, block, all makes a big difference.
  3. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    It is in a new Edelbrock Intake Manifold. Please don't ask how it got there it just needs to be filled and a new one drilled where the old hole was.
    ThaNKS
    Adam
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    sounds to me like you need a pipe bushing.
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Can you just heli coil it?
  6. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello
    I am wondering if that will work with what has to be done. See I bought edelbrocks "Performer EPS with PermaStar finish" for my 1985 K5 Blazer that I am making into a off-road / show truck. I had it all in and I was putting in the last bolt in the carb and I heard a popping sound. Well that sound was the bolt breaking off in the hole. Well the spacer and carb I have had two holes so they could fit different Intakes. So I just figured I would drill and tap a new hole. So I put the spacer on and put bolts in the three other hols to help line everything up. Well I did not bolt the spacer down so it was moving all over. And by the time I was done I had a hole about a 1/16 off from where it needs to be. Now when I have the new hole drilled by someone other than me the new hole will go almost half into the hole that I drilled.
    So will a bushing work?
    Adam
  7. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    jb weld?
  8. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    jb weld?
    Will JB weld hold up to the forces?
    Adam
  9. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    jb weld?
    Adam
    [/ QUOTE ]I have used jb weld for my breather hole in my pumpkin and it is still there with nothing falling out yet. /forums/images/graemlins/woot.gif
  10. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    you sealed up the breather hole in the pumpkin??? /forums/images/graemlins/screwy.gif
  11. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    [/ QUOTE ]sorry I didn't explain enough. the piece that has the tube coming out of the pumpkin kept on coming out, so I used the JB weld to lock it into place so there is still venting. /forums/images/graemlins/smirk.gif
  12. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    Dude, take the manifold to qa good welder (that can weld aluminum) have it welded up the have a machine shop do the drilling and tapping if you don't feel comfy with it! /forums/images/graemlins/waytogo.gif
  13. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Just making sure you didnt go crazy /forums/images/graemlins/thumb.gif
  14. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    a new manifold is cheaper then the repair
  15. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    Is it the rear carb hole? is so, can't you just widen the carb hole itself to make it fit. Also, If you still have the receipt for the intake, its amazing what stores will take back for a "it's not the right one" refund! Just make sure the person at the counter is REAL busy . /forums/images/graemlins/whistling.gif
  16. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    If the hole is out of round, or if your new hole is going to take close to half of your original hole, just drill it out to the next common thread size, if it's drilled ok, but just in the wrong place, tap it and locktite in a piece of threaded stock. file it flat, center punch and drill your hole in the right place. A specialty fastener store can get you aluminum bolts to use for filling this hole, (some states use on their road signs) that would make it easier to drill with out the bit wanting to "walk" to the softer metal..
  17. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    I don't think so this baby was $208.00 so I don't think buying a new manifold is in the ?.
  18. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    I am liking this idea.
    I don't want to spend the extra money taking the thing back off.
    Adam
  19. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Yes it is the rear carb hole. If any welding has to be done I will pop the thing off and take it to the shop.
    I got the damn thing online at summit so it will not work.
    Adam
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    A new manifold is the only answer to your question. Paying a machineist to fix it will cost more than buying a new manifold.
