Filling in holes on body
Discussion in 'The Body Shop' started by hi pinion, Oct 20, 2004.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    I have some small holes in one of my cars, because the old emblems were there, i was thinking how to fill these holes??? /forums/images/graemlins/confused.gif So i can repaint my car. I wouldnt want to use filler, but to fill them with metal. /forums/images/graemlins/thumb.gif
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Why not use filler? It's not like you're going to have to worry about rust. /forums/images/graemlins/dunno.gif
  3. hi pinion
    Sep 25, 2003
    5,354
    Im just worried about filler not working. /forums/images/graemlins/crazy.gif i dont want the paint to get done, and then have problems with holes re-appearin later /forums/images/graemlins/ooo.gif
  4. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    LOL...Yep...dent them in...fill'm. /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/yikes.gif
    I'd MIG them...myself...
    If you take your time...
    and get the welder dialed-in...
    NO filler should be needed.. /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif
  5. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    YOu weld the holes then grind it smooth.
  6. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Definitely mig weld then smooth. Turn the wire speed up a little too high and you can do it in one quick pass.
  7. hi pinion
    Sep 25, 2003
    5,354
    Its not for my beater chebby, its for my 1960s muscle car /forums/images/graemlins/thumb.gif i would want to ding it in, then fill it /forums/images/graemlins/histerical.gif /forums/images/graemlins/thumb.gif I was thinking it would be a pain to weld a hole up,i would think it would make it bigger. Mabey just "build it up" with the welder /forums/images/graemlins/thumb.gif
  8. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    actually if you have access to the back side i have seen and heard of people using small washers (like backing washers for rivets) to help weld up the hole, you have a nice backing piece of metal to, use a rivet or a nail to hold it place then when done push the nail/rivet through and weld up the tiny washer hole /forums/images/graemlins/thumb.gif
  9. hi pinion
    Sep 25, 2003
    5,354
    I think my membership has paid for itself 10x over already /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thumb.gif keep em comming !!!! /forums/images/graemlins/thumb.gif
  10. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    You can call it a mustang, it's ok.
    That is how it's done. You weld the holes shut and grind them smooth. It is easy if you know how to weld well.
  11. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    The other trick to MIG'ing the holes shut is to use a backing material like copper or aluminum when you weld. It gives the filler a backer so that the weld can puddle up and fill the hole, but it doesn't stick to the weld. When you're done, you can easilty remove the backer and it looks good from both sides....
    I've had reasonable success using old license plates as backers (aluminum) but I'd like to try a thicker piece of copper to prevent the occasional burn-through...
  12. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Greg, I've had great success using thin brass as a backer /forums/images/graemlins/thumb.gif
  13. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Thats it right there. Plain and simple. Weld it, then grind it. Any questions?
  14. paulmoon
    paulmoon 1/2 ton status
    Feb 11, 2004
    211
    Reno, NV
    Welding works best. I was able to use a brass backing plate to help fill the holes. I've also used fiberglass reinforced filler with success. But perfer welding. For a nice 60's car I vote for welding.
  15. michaeltouche
    michaeltouche Registered Member
    May 27, 2004
    7
    Longmont
    I used finishing nails, drop the head in the hole the weld the head till melded the the body. grind smooth touch up with some body filler
