Filling the T-Case
Discussion in 'The Garage' started by RAY, Jan 1, 2005.
  1. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    anyone have an easy way or trick to fill a 208. I have tried a syphon pump, but I usually end up with a giant mess that takes longer to clean up than it does to fill the T-case? :mad: So let me hear your suggestions.
    Thanks,
    Ray
  2. sweetk30
    Nov 1, 2004
    25,553
    547
    horseheads , ny 14845
    fill info
    i full the pump and put cap on then fill tcase works good . havent had much luck sifhening with them tho. try this: long hose up behind cab with funnel and fill. work good with buddy watching.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I have an on/off valve that threads onto gear oil containers and also has an adapter to screw onto tranny fluid/oil containers . I use it with the hose for rearends gravity fed , and without the hose for transfercase . I just stick the nozzle into the fill hole and squeeze the bottle . Autozone for like 3.99 :)
    I have also used the nozzle caps off of old gear oil bottles in quart size , and the nozzle caps off Lucas additives , they thread onto the tranny fluid bottles too :k5: :k5:
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Same here. The pump works ok, but the little screw on hose with the on off valve makes it alot easier.
    Harley
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I use the tops off gear oil. I always save those cause they are so useful. A piece of tube off the end of that top will make it even easier. a 5 gallon drum with a pumper top on its the easiest way ;) just have to go slow when you think are getting close.
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I use the little screw on thing that comes with the gear oil, works good:xmas:
  7. dcell152
    dcell152 Registered Member
    Sep 23, 2004
    84
    Nothern Maine
    the only way to go
    I use a 5 gallon pail with a pump. Works great!! Fluid is usualy cheeper bulk to.
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i did use one of those extentions with the on/off valve, but the last time i couldn't find it so i used a gear oil top. both work great.
  9. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Ok so what do you do if the filler nut on the case doesnt wanna come off? Ive tohught about puttin some heat to it.
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    ive never had a problem, try a socket and an impact, should get it off. imnot sure what size it is, i always used a cresent wrench.
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    1 1/4 or 1 1/8 I believe. Either way it shouldn't be too hard. the case is aluminum so nothing should be insanely torqued, remember not to torque it to heck when you put it back in.
  12. AkMudr
    Dec 30, 2004
    917
    Alaska
    It is insanely torqued from the last guy who owned it, Ive tried everythin and with it bein a shallow plug everythin slips off, Ive had many busted knuckles with this one and would rather not use an impact cuz for fear of cracking the housing. I might try a lil heat.
