Filter Question
Discussion in '1982-Present GM Diesel' started by BARRAZA, Oct 4, 2002.
  1. BARRAZA
    BARRAZA 1/2 ton status
    Oct 17, 2001
    259
    USA
    In my junkyard adventures gathering parts for my m1008, I picked up a factory firewall mounted cannister type fuel filter. The one with the screw on filter with the drain cock on the bottom. My truck has the rectangular filter held on with clips. Is one better than the other? Is there and advantage to running them both in series? If so, which one should the fuel flow through first? Or should they be mounted parallel?
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The rectangular one seems have problems with leaking from the base itself. (That's what happened to mine) I assume yours does not leak, so I wouldn't bother eliminating it until it does. I would save the canister one as a cheap backup as a new base for the rectangular one is over $400 CDN. (I've heard you can also install a pipe plug in place of a particular sensor that usually leaks).
    If you run two filters, they should be in series. Find out what you can get in the way of filters for both units. They are usually rated for a certain micron level. The idea is to run a coarser filter with water separation for the primary, and a finer filter for the secondary.
