Filthy intake manifold: Clean it or buy a new one?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigJim85, Aug 5, 2002.
  1. BigJim85
    BigJim85 1/2 ton status
    Sep 7, 2000
    113
    Lakewood, Colorado
    My stock intake manifold is downright filthy, and coated with carbon. I'd like to stay with the stock manifold so I don't have to screw with anything. Any of you know a place in the south west metro Denver area (south Lakewood/north Littleton) that could clean it for a decent price, or how much a stock manifold for a '85 350 would cost from GM or a good aftermarket manifold that I wouldn't have to buy a whole bunch of additional parts or screw with too much?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Get an Edelbrock Performer. No modifications at all.
  3. joker89blazer
    joker89blazer 1/2 ton status
    Nov 21, 2001
    130
    panama city florida zip 32409
    If you want to have it cleaned you could check with a shop that rebuilds motors are heads, are even a shop that has a bead blast cabinet.If you decide to replace it make sure the intake is designed for the rpm's that your motor runs best at. A intake designed for high rpm's does not work good at low rpm's.
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    If it's a cast iron manifold then any big machine shop should have a "hot tank" they could dip it in and strip it down to bare metal. /forums/images/icons/grin.gif
  5. PGL4VT
    PGL4VT Registered Member
    Feb 10, 2002
    71
    Roanoke, Virginia
    I had mine tanked for about $20.00. Looked great. They'll also check it for warping. Any engine shop can do it.
  6. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    GM dealers have a nasty chemical called Top Engine Cleaner that "melts" carbon in about an hour. It costs between $5-10. I have used this on valves (placed in a old coffee can) and it worked great. Should work just as well for you. Just finding the right way to get rid of it can be tricky.
  7. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    Just have it hot tanked, pick up the yellow pages and call just about any place that says that they do head work, engine work, etc... If you have some sort of technical training school arround they may hot tank it really cheap for you.
  8. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Oven cleaner works pretty good.
