Final drive ratio?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 2Dogs, May 4, 2001.
  1. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Hello All, (If this site is truly back online)
    I need the gear ratio for 4th/OD on my 91 K5. It has the 700R4 (4l60) auto. Thanks -Dave
  2. dyeager535
    26,981
    .70
    Dorian
  3. CK5
    May 19, 1999
    21,627
    704
    CO
    Dave
    Hit the specs page, it has all that info. Just click on the "Trail Map" and you can jump right to it.
    Steve
    Mall-Running poseur 4x4 with curb-feelers
  4. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I see the first gear ratio but I must be missing 4/OD.... I am looking at the specifications page for
    the 91.
    My question is what will be my freeway RPM with 4.10 gears and 35"tires?
    NP241 is 2.72:1 so all I need is 4th....
    I use the blazer as a weekend toy hauler also so am curious about freeway speeds/RPMs. With the 32" tires
    and 3.08 gears I have now, I need to be doin about 90 before I can shift into OD. :) Dave
  6. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
  7. dyeager535
    26,981
    yes.... .70, 1, and your axle ratio will give you final drive.
    Dorian
  8. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    OK, 65 MPH on the freeway, 4.10's in OD (0.70 to 1) Assuming a true tire diameter of 34.5" your new freeway RPM will be about 1816 RPM. Same combo in Drive 2595 RPM.
    Hope that helps.
    BTW welcome to CK5! [​IMG]
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
