Final RPM ratio calculation
Discussion in 'The Garage' started by Bullet, Dec 13, 2003.
  1. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    For the sake of my laziness...
    Currently I run a 700R4 (3.06) NP241 and One tons with 4.56 gears to spin my 37's right now to go down the highway at 70 the 383 turns over 2000rpm
    I plan to swap to 5.13 gears and 38's can anyone tell me if how far or close I will be to my old ratio? I lokked at the chart at 4Lo.com and its a little help, but is there any better exact way to finding out what my REVs are going to be? Thanks /forums/images/graemlins/thumb.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    final drive ratio on the setup you have now is 3.19, with the new setup would be 3.59. At 3,000 RPMs in overdrive now you should be able to do 103, with the new setup would be 94. Personally I'd try the 4.56s and 38s and see how it is. I don't think I'd go with 5.13s unless you want some crawl ratio, even then the crawl ratio doesn't jump much between the two.
  3. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Here Matt
    Speed (mph) x gear ratio x tranny ratio x 336 (355 for non lock up auto's) all divided by the tire diameter
    75 x 4.56 x .70 x 336 / 38= 2116 rpm
    75 x 5.13 x .70 x 336 / 38= 2460 rpm
    The bigger tires are heavier so a little extra gear helps get the truck moving like it did with the smaller tires. The lower gears also make things a little easier on the 700R-4.
    Rene
