Finally driving the Blaze...
Discussion in 'Pacific Region' started by k2-k5, Sep 30, 2004.
  1. k2-k5
    k2-k5 1/2 ton status
    Sep 30, 2003
    285
    Vancouver, WA
    Two months it took to get the steering arms and tie rods made. Of course now the tranny is slipping /forums/images/graemlins/frown.gif
  2. grundy99
    grundy99 1/2 ton status
    Sep 13, 2004
    389
    Loveland, CO
    That is a nice looking blazer /forums/images/graemlins/thumb.gif
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    That is one good looking rig man /forums/images/graemlins/thumb.gif Wanna take it up to TSF on saturday with the Jeff, Brian, and I. Hopefully Ryan will get to ride shotgun w/ me. /forums/images/graemlins/cool.gif
  4. k2-k5
    Sep 30, 2003
    285
    Vancouver, WA
    I have to get the tranny fixed first. It don't seem to want to go into shift into drive. Driving all the way to TSF in 2nd don't sound like a good idea. I'm going to try a different vacuum modulator first then the tranny gets rebuilt.
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Hmmm modulator... /forums/images/graemlins/thumb.gif /forums/images/graemlins/deal.gifCheck the line that go to it also, I think the can be adjusted as well with a slim screwdriver... /forums/images/graemlins/thinking.gif /forums/images/graemlins/dunno.gif
  6. k2-k5
    Sep 30, 2003
    285
    Vancouver, WA
    i have heard that. But which way do I turn the little screw?
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    all adjusting the modulator will do is make it shift firmer and to do that you turn it clockwise
  8. chevyfumes
    Feb 24, 2000
    38,584
    266
    Yeah but if it's adjusted too far in one direction it wont shift at all... /forums/images/graemlins/dunno.gif
  9. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    You're running a TH350 right? The vaccum modulator won't do jack for that. You can try it, but chances are it won't affect it one way or the other (AFA engaging gears). On the drivers side of the tranny, behind the shift linkage, about the middle of the tranny pan, there should be pressed in round cover with heavy wire strap holding it in place (kinda like the caps are held onto the brake master cylinders). Inside there is your shift governor. Pull that cover and slide out the governor. If the teeth are all chewed up on the plastic gear and it's covered in metal shavings, your tranny is toast. If they're not chewed up and the fluid looks good and doesn't smell burnt, change out your fluid and filter and see what happens.
  10. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    Very nice /forums/images/graemlins/waytogo.gif God man your killin me with the orange first gen pic. Good luck with the tranny issue I hope its nothing serious.
