Finally found one
Discussion in 'The Garage' started by 79k20350, Sep 9, 2005.
  1. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Ok so i finally found a 32 spline sm465-205. The 205 has a fixed yoke rear too. woohoo! so how much you guys think is fair. its a good ways away (about 3 hours) so i figure 80 for gas and im hoping i can get it for 150-200. no shifter on it and the guy left the pto cover off for a month so theres slight surface rust on the gear face but nothing bad, im not worried about it. i have a shifter already from a prvious project too... what do you guys think its worth?? thanks alot!
  2. dyeager535
    26,980
    yeah 150-200 isn't bad. Not a steal, but fair.
    The shifter changed along with the adapter in 1985, sorry to report. The longer output shaft puts makes the adapter 3" longer, the older shifter won't clear the cut in the floor.
  3. 79k20350
    Nov 22, 2004
    7,757
    Ct
    not the t case shifter, the tranny shifter. i know about the change in adaptor. thanks!
  4. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    He was just saying that if you already had a 205 in your truck that the t-case shifter would no longer align with the factory hole.
    Either way, it sounds like a steal to me, that is, if the internals aren't pitted from rust. Shifters are a dime a dozen.
  5. 79k20350
    Nov 22, 2004
    7,757
    Ct
    nope, just surface rust. it wipes right off. right now i have a 400/208 combo so its a big swap anyways and more holes are gonna have to be cut in the floor
