Finally got my tow rig back to snuff
Discussion in 'Tow & Trailer' started by Sandman, Sep 8, 2004.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Last camping trip, I had the slide in camper on and was towing the trailor with the blazer on it. I had all kinds of noises and grinding sounds coming from all over the drivetrain. I didnt think I was going to make it home! In the end I ended up replacing...
    - Bearing style of pilot bushing. The bearings were piled up in the front with just the outside housing still there.
    - The Clutch. In OK condition. A little burnt though.
    - Throwout bearing. Bearings were shot.
    - Carrier bearing on the driveline. It was bad enough that you could move the driveline around by hand and the bearing itself was very loose.
    - Ujoints on driveline. Two were OK. the middle one had been overheated, no grease at all (sealed version) and one of the caps had a fine powder instead of the roller bearings in it.
    - Fluid in the NV4500. Last owner had put gear oil in it. Syncros were starting to whine and it would get real hot everytime I hit the freeway or pulled a load. I could smell the oil in it. I found the correct lube for it at the dealor for $9.91 per quart.
    This was on my '92 Dually 4x4.
    I'm glad I've got it done. I've got a few cords of firewood to haul tomorow. Should last me years now. /forums/images/graemlins/thumb.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Autozone sells synchromesh for about $4 a quart. /forums/images/graemlins/frown.gif
  3. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Glad you got it all worked out. /forums/images/graemlins/thumb.gif Sounds like it needed some TLC.
    John
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    DOH! /forums/images/graemlins/doah.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah it's only one brand, I think Pennzoil, and it's not on the front, you've got to check the back of the bottle to varify.
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Doh! didnt you see my "For those of you with NV4500's" post?!@#?!@#! like 8 months ago?!@# /forums/images/graemlins/doah.gif
