Finally got the BBC in the garage...UPDATED pics
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ak bandit, Aug 10, 2005.
  1. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    Hopefully it wont be too long until the 396 (402ci) is in the K5. I just ordered $800 worth of parts from Jegs, so I'm waiting for Mr.Postman anxiously. I've started to clean it up, prepping it for paint. Man I sure hope it fits in there!
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Cool!
    It will fit...barely :D
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    If you have the small valve covers it will clear better..
    If you put in some roller rockers and a stud girdle and end up having to run tall valve covers, then it will be worse. :o
    Some guys use a sledge to make it clear, or you could cut a section of the firewall out and patch in a step if its that bad. (go look at hot rods with BBC at a car show. :wink1: )
    Burt, Did you have to Use the sledge a bit?
  4. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    No sledge or hammering at all on mine. Fits like a glove :D
  5. Burt4x4
    6,854
    I did bang bang on the firewall a tad bit. At first I bent up the wrong spot, about two inches too far toward the fender on the driver's side. So the head is about 1/8" away from the firewall but I can still remove the vavle cover and with the ORD HPengine mounts my 454 does not move at all so the 1/8" I have is fine even though it could have used one more WACK! You can't even see the dent that much as the engine blocks it from view :D and all the black paint kinda blends it all together ;)
    Burt
  6. ak bandit
    Sep 10, 2004
    386
    Eagle River, Alaska
    I think the valve covers are close to stock height. Plus I've got a 3in body lift, so I'm thinking that'll make it easier. Also I'm using SBC engine mounts. But I dont have a problem with beating on the firewall to make it fit either. I'm more concerned about the headers and oil pan not clearing :crazy:
  7. ak bandit
    Sep 10, 2004
    386
    Eagle River, Alaska
    I need to get a new oil pan pretty soon. I'd like to find one that will fit without any crossmember modifications. Would a stock 5qt pan work?
  8. Burt4x4
    6,854
    I too have a 3"body lift.
    See I also used a engine mount cross-member from a 73+ SBC 4x4truck. This alowed me to use ORD's HP engine mounts wich I belive is key to keeping my 454 from moving as clearance is tight in 3 spots, driver's side head, pass side header & oil pan to x-member.
    This isn't a very good pic but inbetween the pan and the top of the x-member is about 1/8" of clearence. The pan I am using is a GM pan that has a windige tray (sp?) & baffel (I think that is what it's called, I haven't thought about the terms in a while and I could be miss-speaking them??)
    Anyway I hope this helps.
    Burt
  9. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    those valve covers look just like a set I had once, they were hollys and looked pretty nice :D
  10. ak bandit
    Sep 10, 2004
    386
    Eagle River, Alaska
    One step closer to the big block swap! :D
  11. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Engine looks great - definitely worth putting a nice coat of paint on.
  12. Burt4x4
    6,854
    If there is a picture in your post I can't see it. Are you remote linking a photo from somewere? If so my work's firewall is probly blocking it... :mad:
  13. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Here ya go, you could probably have seen it from home but this is too good to make you wait. :D
  14. Burt4x4
    6,854
    Oh ya that looks SWEEEEET! :D
  15. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    looking good, Nice set of accessories too :D
  16. bamf
    bamf 1/2 ton status
    Aug 27, 2005
    170
    Fayetteville North carolina
    i wanna build a engine but i dont know how and never done it ><
    its looks Real pretty
  17. destinbeachman
    destinbeachman 1/2 ton status
    Aug 31, 2005
    365
    Florida
    Oh yeah,it'll fit,and you'll love it!Mine is set back 6 inches with a custom crossmember for better CG and my body lift is 3 inches.No probs.I need to look into those ORD mounts,though.
