Finally hit a snag with the D60 buildup...
Discussion in 'The Garage' started by fortcollinsram, Jun 12, 2004.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Well I was kicking butt on the D60 rebuild untill I threw the 1.5" ORD tie rod on and checked for diff cover clearance... Well, the rod clears the stock cover but hits my Crane diff cover just before full right lock. /forums/images/graemlins/yikes.gif
    Do you guys think I should take a grinder to the cover for a bit of extra clearance (only need like 3/32" to make it clear) or should I just adjust the lock-stops on the knuckle to prevent it?
    I am kinda leaning towards for several reasons:
    -The cover is nicely powder coated (don't know why I did this, because the rest of my truck looks like sh!t)
    -don't wanna make a beefy cover thinner
    what are your thoughts...
    Chris
  2. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    can you take that 3/32 off the tie rod? which of the 2 can stand to lode that minute amout more /forums/images/graemlins/whistling.gif
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    let it rub long enuff and it will split the differance for ya!!! /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    Sorry not being very help full am i? i'll shut up now. /forums/images/graemlins/whistling.gif
  4. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    If the flange of the diff cover is thick enough you might be able to grind some off there. Or you might be able to comprimise and take a little from the tie rod, cover face and cover flange OR take some off of the cover flange and adjust the lock-stops a little. /forums/images/graemlins/waytogo.gif
    If it was mine I would go with the last option if the first option failed.
  5. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    I put the same tie rod on a month or two ago. Hey, you need ALL the steering you can get from your rig. I would not adjust the stops to limit tie rod rub. I hate to break your heart, but I would go with the stock diff cover.
    Just my 2/100th's of a dollar.
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    would changing to a higher mount tierod dodge knuckle help that?
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Can you say Hysteer /forums/images/graemlins/thumb.gif
    Are you running a gasket between the cover and diff? If so take it out. That will gain you a little clearence. The flange on that cover is probably pretty thick, and as long as there would be no ring gear interference you might have it machined down a little.
    Last ditch would be grind the cover. DO NOT grind the tierod. That creates a weak point in it. I wouldn't adjust the steering stops either. You would be killing part of the point of crossover steering. You will loose some of the steering radius you gained from going to crossover.
    Harley
  8. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Thats what I was gonna say, HI Steer. But of the two choices on grinding, I think I'd grind the diff cover.
  9. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i would put a block of wood between the cover and a hammer(so as to not mess up your powder coat) and "massage"it a little bit /forums/images/graemlins/waytogo.gif
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Your not going to "massage" a Crane cover. I think it is like 3/8 or 1/2 thick. They are BEEF covers designed to slam into rocks all day every day. The only thing that will get massaged is you ego & arm.
    Harley
  11. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Yeah, you will not be clearancing the diff cover with a hammer at all, at least not with a hand held hammer...a pneumatic jack hammer on our Bobcat 873 might do something, but I digress....
    There is NOT gasket on the cover...just RightStuff sealant...I think I am going to run it like it is and break in the gears and when I pull the cover to change the fluid, I will take it to a machine shop and see if they can fly-cut the flange like .060". I am sure it doesn't help that the dude that powder coated the cover put a nice thick coat on the cover flange...
    Chris
  12. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Id run it, worst thing that can happen is something will break. /forums/images/graemlins/whistling.gif Hell my tie rod hits the diffcover when I bash it on something.
