Finally no more exhaust fumes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, Sep 23, 2002.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    This week end I had my exhaust moved to come out in front of the left rear tire and finally I can drive with my rear window open without inhaling those nasty exhaust fumes. I realize this is not the best option for clearance but since I do most of my driving in the desert and in the dunes it should be OK. As an added bonus the exhoust now has a deeper rumble to it since the exhaust now ends only aprox. 20" from the flowmaster. /forums/images/icons/smile.gif /forums/images/icons/cool.gif
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Thats good to know! I finally took my top off and left it off to combat the fumes.. but now, I might look into routing the exhaust there.
    Your rather close, there's a run in Truckhaven Hills this Oct 20th which is over by the Salton Sea.
  3. GloNDark
    GloNDark Registered Member
    Sep 4, 2002
    22
    Gardnerville NV
    do you have any pics of how it was re-routed? just finished putting headers, an cross pipe and a flow master on my 85 and I am trying to figure out the best way to dump the tip out in front of the tire.
    Thanks!
    Chris
  4. bajaviking
    Apr 10, 2002
    752
    Baja
    I will try and take some pictures so you can see where it comes out. The Truckhaven thing sounds like fun, do I need to register in advance or can I just show up. Please let me know the details. Thanks.
  5. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I think this year it will be the first SoCalBigDawgs Safari, they are a good group to wheel with so you can just show up.
    Theres a thread on it in the SoCalBigDawgs forum on CK5.
  6. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    I did the same thing, no fumes at all anymore, top off, window open, doesn't matter. [​IMG]
    It does kill ground clearance a bit, but that will be fixed after the body lift (allowing me to route over the frame rail instead of under it.) Also thinking about dumping out from a cut out in the rocker panel.....
  7. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
    why does moving the exhaust closer to the window remove fumes. You would thing routing it farthest back would be better.
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i think marv_springers exhaust is like that... might want to shoot him a line for a picture.
    i am thinking of a stack out the back of my bed just behind me, the future driver, with a few layers of metal shielding. then make it an inch or so higher than the roll cage if i roll over.
    grant
  9. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Here's a pic of where mine exits....
    Marv
  10. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    In my last blazer, I had the exhaust angle down, out, and dump just before the back axle. I never had an exhaust smell. When I put my 454 in, I'll probably do the same thing. It's a bit louder, but not too much. Plus the exhaust was tucked up inside the frame rails, no clearance issues at all. /forums/images/icons/laugh.gif Just a thought.
  11. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    Shane74, just for clarification : your exhaust is similar to the style where it (more or less) straight back between the frame rails with turn downs in front of the rear axle, with the exception that your turn downs are angle like 45* towards the side so that they would blow out towards the front of the rear tire?
  12. bajaviking
    Apr 10, 2002
    752
    Baja
    Mine comes out in about the same place as yours, except mine is a straight 3" pipe.
  13. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,073
    485
    Grand Rapids area
    It is the rear window (tailgate) that is brining in fumes, not the side windows. The air moving over the truck creates a vacuum back there that sucks exhaust fumes in. The door windows aren't a problem since the air is always moving back past them as you drive.
  14. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Exactly! /forums/images/icons/laugh.gif Sorry, I should have clarified more. /forums/images/icons/crazy.gif
  15. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    No need to apologize you were clear, I just wanted to make sure I had it correct as I am taking notes for my next project. /forums/images/icons/cool.gif
    Thanks again!
  16. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Marv you crack me up! I notice in that picture you now use the tailight as a storage bin for extra oil!!!! /forums/images/icons/grin.gif
    Too funny!
  17. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    You could cut a hole in the fender and vent it out the side. Like some of the new cars are doing exhausts out of the rear rollpans. Might melt some paint? Jeremiah
