Finally starting the BBC project PIC
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by steve_kibbe, Nov 4, 2004.
  1. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I'm so excited......finally get some time to tear down the old Big Block /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gif
    Here's where it sits.....for now.....tearing it down tonight /forums/images/graemlins/peace.gif
  2. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Congrats. What will you be doing to the motor? Mine looked a bit worse than that when I started - lots of elbow grease later and she turned out real nice.
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Sweet!!
    Yet another k5 with a BBC!! SWEEEET!!!
  4. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Cool! You will be suprised the differance you will feel once you get it installed in your blazer. I was. /forums/images/graemlins/peace.gif
    BTW I got the shifter Thanks /forums/images/graemlins/waytogo.gif
  5. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    right now I'm just going to take it apart to see what needs to be done, I want to balance the bottom end, new cam...of course. I've thought about stroking it out, but we'll have to see what the budget says. I was looking at the 496 kits /forums/images/graemlins/peace.gif
    I do have a question for y'all though.
    What cam would you suggest???
    I haven't descided....but I was looking at comp 4x4 extreme
    I think crane also has a truck cam....
    What do ya'll think, help me build this motor /forums/images/graemlins/thumb.gif
  6. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Hell....I better, it only had the stock 307 /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    PS glad you got the shifter /forums/images/graemlins/thumb.gif
  7. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I went with the Crane Energizer 266 for my 454. I had a pretty knowledgeable guy help me figure out what was best and this was his recommendation for gobs of low end torque. I then called Crane and they made the same recommendation.
    The guy who helped me pick this came said the Truck cam was also a good choice but not really worth the price difference.
    I went with that cam, along with Crane springs & retainers, and Comp Cams roller rockers. What will you be doing for fuel delivery? I went with the Jet Stage II Quadrajet, again on the recommendation of my friend. He has had great luck with them. Fuel injection was outside of my budget.
  8. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    wellll...I'm finally taking it off to the machine shop tomorrow AM. The cylinder walls look real good. The only real big thing I'm gunna do is put big valves in the heads. I'm going with the 2.19/1.88's. I haven't descided on a cam, but I think I'll give Crane a call like Yukon Jack did. I'm going to replace the all the bearings, rings, the valve springs, and the rocker arms. I'm hoping to be able to hone out the cylinders. I can't wait until I can fire this thing up!!!!!
    I'll try to keep y'all posted
    --Steve--
  9. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I'm reading some good stuff on Comp Cams Beehive shaped springs. On a pretty wild build they picked up 30 hp using them, that is substantial from just valve springs.
    Glad all is looking good so far.
  10. Burt4x4
    6,854
    Sweet! Sounds like what I did. Oh but I went with a Comp cam. I hope to yell "Fire In the Hole" very soon...Stupid holidays are getting in the way. I too can't wait to drive again /forums/images/graemlins/peace.gif
  11. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    which cam did you use burt???
  12. Burt4x4
    6,854
    I have a print out...here it is...
    Comp Cam Grind number CB X4 254H-11
    part # 11-231-3
    Duration @ .05 intake= 210 exhaust= 218
    Lobe lift = .297
    Lobe sepration = 111
    CompCams recomended this grind to go with my 454 using the Edelbrock MPFI intake and a 9.5:1 compression ratio, built for lowend torque. Basic BBC stump puller /forums/images/graemlins/woot.gif
    Hope this helps, I am no gearhead so I relied on my engine guy to work with CompCams to figure out what cam would be best for my build up /forums/images/graemlins/waytogo.gif
  13. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    The bigger valves will probably hurt your bottom end a little bit, but that's what gears are for.
  14. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    update............
    Heard back from the machine shop, they did have to bore it out 030 over.........so I haven't descided on pistons yet. Any sugestions????
    The heads are coming along nicely......going 2.19's and 1.88's Totally reworking them, new guilds, seats, and all that stuff.
    I'm taking them the crank and rods friday to be balanced and all.
    I heard YukonJack's clip, damn, I can't wait
    I might lookinto the same cam, sounds great.......
    thats it for now,
    --Steve--
  15. Burt4x4
    6,854
    I have Keth Black pistions. I don't have the part number off had but I do have it at home.
    Hope this helps
