Finally.....
Discussion in 'The Lounge' started by readymix, Jan 9, 2006.
  1. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Made it to Temecula. Now it's time to relax:D ....then fix my truck:mad:
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Welcome!!!!!!!!!!!
    And let me know if you need a hand I can try and come up after work. It is about 1-1.5 hrs for me:o. And I have minimal tools:doah:
    Ira
  3. readymix
    May 30, 2004
    6,706
    26
    It should only be one hour north of you. I have almost every tool you could ever need on Chevy with me. Air tools and homebrew power tank included.
    I need to remove the rear section of the NP208 and tap the breather hole so i can install a NPT barb. Should not take too long aslong as i can find a gasket first.
    Then rebuild both rear hubs and replace the seals, same for the front.
    Finish it all up with a complete fluid change and it will be good to go for a while. I am not sure when I will start it, but knowing me it will wait a while
  4. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i'm not too far either, any my dad lives off the 215 and the 60, so I drive out that way sometimes, Welcome!
  5. readymix
    May 30, 2004
    6,706
    26
    Anyone have a part number for that gasket?
    I don't know anything about the parts stores here and would like to go prepared.
  6. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i dont know the part number, did you check the part number thread?
  7. sandawgk5
    Oct 28, 2003
    6,881
    I have always seen pictures of it sealed with permatex.
    Ira
  8. readymix
    May 30, 2004
    6,706
    26
    I have been searching, and most say to just use gasket maker. Guess that will do.
  9. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Yep, no gasket. GM calles for GMS.
  10. sandawgk5
    Oct 28, 2003
    6,881
    GMS= General Motors Sealant?
    Ira
  11. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Gasket Maker
  12. readymix
    May 30, 2004
    6,706
    26
    Now all i have to do is face the fact that I can no longer work in a garage. I got so used to having one for the last 3 years. There is one here, but the truck is too tall. To top it all of, I can't even work in the driveway as it is too steep for me to feel comfortable with the truck on jackstands.
    So anytime I need to work on the truck, it will be a minimum of 100ft from the garage.
  13. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    you are still in the service right? just use the hoby shop here at pendleton. im only about 25 min from you with trafic. maybe a lil more.
    sorry you are in cali... ill be leaving soon!! whoohoo!
    Grant
  14. zeroz400
    zeroz400 1/2 ton status
    May 30, 2004
    410
    Libertyville, IL
    You got your kegerator hooked up? That might make the 100ft trip worth it:D Atleast you dont have to anything major without the garage, to bad i never got smart enough to finish my truck and go muddin with ya.
