Finaly got my body mounts changed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stickseler, Nov 15, 2002.
  1. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    This is actually the first major job I've done on my truck by myself ( with a little help from the wife ). /forums/images/graemlins/grin.gif I'm so glad my boss let me play hookie today since it is gona rain tomorow.
    New ORD body mounts and 1" Body lift, and new 33's. I'll have to get a better pic when it's bright out but I was excited /forums/images/graemlins/grin.gif
    Before: /forums/images/graemlins/frown.gif
    After: /forums/images/graemlins/laugh.gif /forums/images/graemlins/thumb.gif
    Now all I've got left to do is sandblast and paint above the tank and put the new tank on underneath.
    And I think the old mounts were shot:
    I AM SO HAPPY WITH MYSELF /forums/images/graemlins/laugh.gif /forums/images/graemlins/grin.gif
  2. pilgrim
    pilgrim 1/2 ton status
    Sep 10, 2001
    247
    new hampshire
    great job redoing the mounts! i redid mine when i first got my rig and boy what a job that was. keep up the good work.
  3. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    im not even going to bother with it with the truck i got right now...i dont plan on hanginng on to this blazer to long..needs to much work and i cant afford it at my age..so i plan on driving it till i get money for a nicer rig...
  4. mattyblazer
    mattyblazer 1/2 ton status
    Sep 22, 2002
    202
    Long Island, NY
    Nice, did you have any trouble in the bed area?
    Matt
  5. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    Just a few, I got everything loose without droping the tank, but the I realized I neded to drop it to get to the lower rear bushing, it's kinda between the tank and frame. One of the rear bolts spun so I choped the head off and hammered it down from the top. Ijust had to use a washer because I tore up the hole with the wizzer. I also had rust from the rot fill up one of the bushings I just hit it for a minute with the air hammer from the side till all the crap fell out and it came right out.
    My other problems were:
    The washer under the cab mounts were rusted...Bought all new from LMC
    The upper washer on a few of the front mounts were rusted a bit so I replaced all those too, the LMC ones were a little big for the poly mounts but I put a little lithium greas on them and they poped right on.
    Once I figured out what I was dooing and got all my new parts in it only took 2 hours to replace all the mounts. It probably took 4 hours to get everything loose and apart.
    Those were the only problems. I didnt use an impact, I soaked all the nuts with PB Blaster for a few days then used a 3' pipe and 1/2" drive w/extensions. The wife pulled the breaker bar while I held the ratchet. If you do it I'd recomend having new tank straps handy, One broke while I was taking it off, but I already ordered new one ( and tank, sender and pump ) I figured It's all apart may as well do it right. If anyone needs a sender check GM Parts direct they were half the dealer price.
  6. mattyblazer
    Sep 22, 2002
    202
    Long Island, NY
    Totally cool! sounds like you have all the bases more than covered. I got mine in about a year ago, but when I got to the last 4 I discovered that the floor was sh!t, So I got a new bed floor from chevy, and I will take it from there, I bought a new pump and screen, like you said while its apart might as well change it.
    Well thanks for the info
    Matt
  7. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I did mine awhile ago.. not too bad are they... I managed to get teh rear's done w/o lowering the tank.. I've done two now w/o lowering tank...
    But it is VERY difficult to get the last two bolts in with the tank still installed...
    Tooke me 2 days to finalize my first one.. and 6 hours on the last one.. nearly by myself...
    Congrats on your first improvement! And a job well done! /forums/images/graemlins/thumb.gif
    What is planned next? /forums/images/graemlins/laugh.gif
  8. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    Ive got new rearsprings coming. Ive got zero rates & Greasable bushings here, then shocks. Then its on to cutting up the inside & get the rust out. I also have new dash & guages to put in.
  9. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    I've done the mounts on mine, a lot of work but the results are well worth it. I'd like to see some underbody pics when you get to it. Very nice truck you got there.
