Finding 454 Serp Belt setup (89)
Discussion in 'The Garage' started by AZ_Overdrive, Dec 1, 2005.
  1. AZ_Overdrive
    AZ_Overdrive 1/2 ton status
    Dec 18, 2002
    117
    Arizona
    Just a quick question. How difficult of a task would it be to locate a complete serp belt setup for an 89 454? I am looking at an 88 454 and it has the older half-serp setup with the compressor on the wrong side.
    Can you get this from GM?
    Any help would be appreciated.
    Thanks!
  2. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Best bet would be a junkyard. GM won't typically carry something that old, but it doesn't hurt (or take much time) to have your local dealer check.
  3. AZ_Overdrive
    Dec 18, 2002
    117
    Arizona
    Thanks for the info. That's what I thought.
    I will pass on the 88 motor and just look for an 89 to 91 454 TBI setup that I can just drop in.
  4. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Buy the entire serpentine kit with or without AC from GM:
    Big Block Accessory Drive (with air) # 12498733
    PRICE: $777.75
    This deluxe serpentine belt drive system with air conditioner includes the components to install on a standard 9.80" deck or the 10.20" tall deck Chevrolet block. The bolts, nuts & spacers along with all the parts listed below:
    Part QTY Description
    10463415 1 Generator Asm-reman CS130
    26010328 1 Pump Asm-Power steering
    12456326 1 Pump Kit, Wat
    01134343 1 Compressor Asm, A/C R4
    10187612 1 Bracket-A/C Cm0pr
    10187613 1 Bracket-A/C Cmpr
    11515757 1 Bolt-Metric HeavyHex Flange H
    10108470 1 Outlet-Water
    10105135 1 Gasket-Water Outlet
    11514189 3 Bolt-M10 x 1.5 x 105.0
    11518034 1 Bolt-Heavy Hex Flange Hd
    10085753 1 Pulley Asm-cr/shf
    11516328 1 Bolt,Hfh
    09440226 3 Bolt-Flg Hex Hd .375-24 x .625
    88986828 1 Belt, W/Pump and A/C Cmpr and Generator
    09442911 1 Bolt/Screw-7/16 x 14 x 4 1/4
    88986813 1 Belt, Fan, W/Pmp, and A/C Cmpr
    12552359 1 Tensioner Asm-Drv Belt
    12552361 1 Pulley Asm-Belt Idler
    10085760 1 Pulley-Fan and W/Pump
    06272959 2 Connector-Therm Bypass Hose
    01470030 2 Clamp, Worm Type (11/16" to 1 5)
    01485552 1 Hose Water Heater .750 ID
    12573728 1 Pulley Asm-P/S Pump
    11515767 3 Bolts Trans BR Brkt
    88961892 1 Bracket, Tall Deck Power Steer
    10187611 1 Bracket-Gen Fr
    10187610 1 Bracket-Gen and P/S Pump
    09442963 5 Bolt Hex Flg Hd
    11515756 4 Bolt-Metric Heavy Hex Flg Hd
    10224224 2 Stud-Gen and P/S Pump Brkt
    03930109 2 Nut-Hex Flg
    10255857 2 Nut-M10x1.5 Flanged Hex Head
    10244168 3 Bolt/Screw-3/8 x 16 x 4 1/4 FL
    11516109 1 Bolt-Metric Heavy Hex Flange H
    24572579 1 Bolt/Screw-Tmg Chain HSG
    11515754 4 Bolt-Metric Hvy Hex Flg Hd(M8)
  5. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    It's $654 at GMParts Direct.
